I need help to configure Cisco 3750g 24 gigabit + 4 sfp
matteocopelli
I bought this switch to use it at home to manage the many home automation devices.
When I first accessed it there was no way to enter express setup mode
Not being able to enter that mode, I then looked for guides on how to remedy the problem but trying various types of configurations, the switch does not assign ip addresses.
I tried configuring vlan1 parameters, I tried configuring vlan 2 with its own dhcp pool but nothing.
What I'm trying to do is connect the switch to my router (192.168.0.1) and I would like the switch to assign the devices connected to it different ip addresses like 192.168.10.xxx.
Can you help me or give me some guidance?
ps. I also tried with chatgpt but it doesn't solve anything. I always get to the point where the switch should start assigning addresses but it doesn't.
Thank you.
M02@rt37
Hello @matteocopelli,
After loading the switch, what have you got as concerned the prompt?
rommon> ?
Best regards
After loading the switch in the prompt I see “switch>”
Results from (w/o quotes) "sh ver"?
Hi, there are the results:
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE12, REL
EASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Thu 28-Sep-17 02:29 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE
(fc1)
Switch uptime is 6 minutes
System image file is "flash:c3750-ipbasek9-mz.122-55.SE12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24TS-1U (PowerPC405) processor (revision F0) with 131072K bytes
of memory.
Processor board ID FOC1341W4WC
Last reset from power-on
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : EC:30:91:A2:7F:80
Motherboard assembly number : 73-10219-07
Power supply part number : 341-0098-02
Motherboard serial number : X.X.X
Power supply serial number : X.X.X
Model revision number : F0
Motherboard revision number : D0
Model number : WS-C3750G-24TS-S1U
System serial number : X.X.X
Top Assembly Part Number : 800-26859-01
Top Assembly Revision Number : E0
Version ID : V03
CLEI Code Number : CNMWS00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS-1U 12.2(55)SE12 C3750-IPBASEK9-M
Configuration register is 0xF
