I NEED OPEN PORT on a cisco 800 series router
ammaralzeer1
I NEED OPEN PORT  on a cisco 800 series router FOR CCTV
I NEED OPEN PORT 8080 TCP/UDP AND 5554 TCP/UDP ON ROUTER
Leo Laohoo
CAN YOU GIVE MY THE default USER AND PASS OR HOW I CAN REST IT .
Go HERE.
Oleg Volkov
Please, write without Caps Lock
In cisco routers, if You not applied access-group on the interfaces, all IP traffic can be flow through router.
If You do not have access to this router, You can reset password, using console port.
In the cisco site, it detailed described.
Also, if router is new, we can try to login with "cisco/cisco"
Helping seriously ill children, all together. All information about this, is posted on my blog
