I tried my first IS-IS lab and there's no connection
hfakoor222
I want IS-IS connection between B5, C5, A5, P5
I have no ping.
I followed a IS-IS lab guide here
https://nsrc.org/workshops/2019/mnnog1/riso/networking/routing-security/en/labs/is-is.html
There may be something wrong with the net statement for addressing. I am posting the runs.
For example debug on R5 showing duplicate systemID which i believe means duplicate router-id
*May 29 2022 11:11:26.647 UTC: ISIS-Adj: Rec serial IIH from ca05.1cd0.001d (FastEthernet1/1), cir type L2, cir id 02, length 1496
*May 29 2022 11:11:26.647 UTC: ISIS-Adj: Duplicate system id
B5#
*May 29 2022 11:11:33.031 UTC: ISIS-Adj: Sending serial IIH on FastEthernet1/1, length 1496
B5#
*May 29 2022 11:11:36.063 UTC: ISIS-Adj: Rec serial IIH from ca05.1cd0.001d (FastEthernet1/1), cir type L2, cir id 02, length 1496
*May 29 2022 11:11:36.063 UTC: ISIS-Adj: Duplicate system id
B5#
*May 29 2022 11:11:42.467 UTC: ISIS-Adj: Sending serial IIH on FastEthernet1/1, length 1496
B5#
*May 29 2022 11:11:44.043 UTC: ISIS-Adj: Rec serial IIH from ca05.1cd0.001d (FastEthernet1/1), cir type L2, cir id 02, length 1496
*May 29 2022 11:11:44.043 UTC: ISIS-Adj: Duplicate system id
i used this command on each router
router isis as50
net 49.0001.0005.0002.00
is-type level-2-only
metric-style wide
log-adjacency-changes all
metric 100000
Do I need to change net statement?
P5 Run
hostname B5
boot-start-marker
boot-end-marker
logging message-counter syslog
aaa new-model
aaa session-id common
no ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
ip domain name ws.nsrc.org
ipv6 unicast-routing
no ipv6 source-route
ipv6 cef
key chain as50-key
key 1
key-string 7 030D481B0A0E23
archive
log config
hidekeys
ip tcp synwait-time 5
ip tcp path-mtu-discovery
interface Loopback0
description Loopback on Border
ip address 100.68.5.1 255.255.255.255
ipv6 address 2001:DB8:5::1/128
interface Null0
no ip unreachables
no ipv6 unreachables
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
ipv6 address 2001:19:0:11::1/127
interface FastEthernet1/1
description BackBone link to Core
ip address 100.68.5.17 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis as50
duplex auto
speed auto
ipv6 address 2001:DB8:5:10::1/127
ipv6 nd prefix default no-advertise
ipv6 nd ra suppress
ipv6 router isis as50
isis network point-to-point
isis metric 2
isis ipv6 metric 2
router isis as50
authentication mode md5 level-2
authentication key-chain as30-key level-2
metric-style wide
set-overload-bit on-startup wait-for-bgp
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
transport preferred none
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
C5 Run
hostname C5
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip cef
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
key-string 7 141E011B000528
archive
log config
hidekeys
interface Loopback0
ip address 100.68.5.2 255.255.255.255
ipv6 address 2001:DB8:5::2/128
interface Null0
no ip unreachables
description BackBone link to Access Router
ip address 100.68.5.20 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis as50
duplex half
ipv6 address 2001:DB8:5:12::/127
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
description BackBone link to Border Router
ip address 100.68.5.18 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis as50
duplex auto
speed auto
ipv6 address 2001:DB8:5:11::/127
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
description BackBone link to Peering Router
ip address 100.68.5.16 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis as50
duplex auto
speed auto
ipv6 address 2001:DB8:5:10::/127
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
end
A5   Run
hostname A5
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip cef
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
archive
log config
hidekeys
interface Loopback0
ip address 100.68.5.4 255.255.255.255
ipv6 address 2001:DB8:5::4/128
interface Null0
no ip unreachables
description Access link to Core
ip address 100.68.5.21 255.255.255.254
no ip redirects
no ip proxy-arp
ip router isis as50
duplex half
ipv6 address 2001:DB8:5:12::1/127
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
description P2P Ethernet Link to Cust4
ip address 100.68.5.34 255.255.255.254
no ip redirects
no ip proxy-arp
duplex auto
speed auto
ipv6 address 2001:DB8:5:31::/127
ipv6 nd ra suppress
no ip address
shutdown
duplex auto
speed auto
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
C5   RUN
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
archive
log config
hidekeys
interface Loopback0
interface Null0
no ip unreachables
no ip redirects
no ip proxy-arp
ip router isis as50
duplex half
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
no ip redirects
no ip proxy-arp
ip router isis as50
duplex auto
speed auto
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
no ip redirects
no ip proxy-arp
ip router isis as50
duplex auto
speed auto
ipv6 nd ra suppress
isis metric 2
isis ipv6 metric 2
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
Hi @hfakoor222 ,
You need to configure
ip router isis as50 and ipv6 router isis as50
on all interfaces that you want include in ISIS.
Also, do a
show isis neighbor
to validate the adjacencies are up between neighbor routers.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
7 Replies 7
georgehewittuk1
The net ID has to be unique for each router.
Follow the following format -
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_isis/configuration/15-mt/irs-15-mt-book/irs-ovrw-cf.html
In the section 'IS Address Assignment' the system ID needs to be unique it is shown what these are. Try making the system ID octet on each router unique
George
hfakoor222
I changed the router id on each router, I can ping directly connected segments, but not loopbacks
A5
router isis as50
net 49.0001.0005.0004.00
metric-style wide
metric 100000
C5
router isis as50
metric-style wide
metric 100000
Router B5
router isis as50
net 49.0001.0005.0001.00
metric-style wide
metric 100000
Router p5
router isis as50
net 49.0001.0005.0003.00
metric-style wide
metric 100000
however I can only ping directly connected interfaces and I cannot ping loopback
My goal is to be able to ping loopback on each router at this point
any advice?
A5
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
archive
log config
hidekeys
interface Loopback0
description Loopback int
ip router isis as50
isis metric 2
isis ipv6 metric 2
interface Null0
no ip unreachables
no ip redirects
no ip proxy-arp
duplex half
ipv6 nd ra suppress
no ip redirects
no ip proxy-arp
duplex auto
speed auto
ipv6 nd ra suppress
no ip address
shutdown
duplex auto
speed auto
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
P5
hostname P5
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
key-string isplab
archive
log config
hidekeys
interface Loopback0
ip address 100.68.5.3 255.255.255.255
ip router isis as50
ipv6 address 2001:DB8:5::3/128
isis metric 2
isis ipv6 metric 2
interface Null0
no ip unreachables
no ip address
shutdown
duplex half
ip address 100.68.5.19 255.255.255.254
no ip redirects
no ip proxy-arp
duplex auto
speed auto
ipv6 address 2001:DB8:5:11::1/127
ipv6 nd ra suppress
no ip address
shutdown
duplex auto
speed auto
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
C5
Current configuration : 2328 bytes
upgrade fpd auto
version 12.4
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname C5
boot-start-marker
boot-end-marker
aaa new-model
no ip source-route
ip cef
no ip domain lookup
ipv6 cef
key chain as50-key
key 1
archive
log config
hidekeys
interface Loopback0
ip router isis as50
isis metric 2
isis ipv6 metric 2
interface Null0
no ip unreachables
no ip redirects
no ip proxy-arp
duplex half
ipv6 nd ra suppress
no ip redirects
no ip proxy-arp
duplex auto
speed auto
ipv6 nd ra suppress
no ip redirects
no ip proxy-arp
duplex auto
speed auto
ipv6 nd ra suppress
router isis as50
metric-style wide
metric 100000
address-family ipv6
multi-topology
metric 100000
exit-address-family
no ip http server
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
Hi @hfakoor222 ,
Also, do a
show isis neighbor
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I configured it on per interface abd it is working perfect. Interestingly enough it's peering across routers too, across more than 1 hop I can ping
hfakoor222
I have reachability between the routers now, however I do not have reachability to the loopback addresses.  Does anyone have suggestion for me to be able to ping loopback addresses?
Hi @hfakoor222 ,
Can you post the
show isis data verbose
output for one of the devices.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I will make sure to do this when I get back and start the lab up later tonight
