I WANT TO DELETE A NETWORK
Luis Polanco
I HAVE THIS 192.168.11.1 IN A SWITCH L3
THE PORT IS NO LONGER ROUTED
AND STILL FOLLOWS THE PROBLEM
AND IF I TURN IT OFF
CONFIGURED SVI IS OFF
A PROBLEM THAT I DO NOT UNDERSTAND WHY
I WANT TO DELETE THIS NETWORK
ANOTHER THING AND I SEARCH WITH THE SH RUNNING-CONFIG COMMAND
AND I DO NOT SEE ANYTHING IN THE INTERFACE
BUT IF THE NETWORK APPEARS
IN SH IP ROUTE
Mark Elsen
 - Note that we can read lower-case post too. Check the routing configuration in the running-config , and or delete the routes you no longer need.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
not sure if this is a production switch, but try:
no ip routing
and
default interface FastEthernet0/2
I believe that the suggestions from Georg should resolve the issue. If they do not then please post the complete current running config.
Rick
