05-01-2013 10:32 AM - edited 03-04-2019 07:47 PM
Ive been trying to get a lab scenario to work that i came up with on my own. Not expecting it to be so troublesome of course. I have the topology pictured below:
The only issue is that R2 cant ping R3 and vice-versa. All the routes show up in the BGP table and the routing table but both branch sites are unreachable to eachother. The only working network connectivity is from each spoke to the hub. All three routers are running BGP AS 100. the frame relay network is 63.100.200.0/29 So the frame relay cloud is all one subnet. The topology is a hub-spoke format with R1 having links between itself and the two branch routers. I believe the issue is the single subnet, but i'm not sure. R1 is acting as a route reflector. There is also next-hop-self configured since natively each branch wont know of the other's next hop. Next-hop-self wasnt working for some reason so i configured a route map to acomplish the same task. Here is my configs for each router.
R1 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
interface Loopback0
ip address 172.31.255.255 255.255.255.255
description BGP Loopback
interface Loopback2
ip address 172.31.1.254 255.255.255.0
description LAN Reachability Test Loopback
interface Serial0/0
ip address 63.100.200.1 255.255.255.248
encapsulation frame-relay
clock rate 2000000
frame-relay map ip 63.100.200.2 102 broadcast
frame-relay map ip 63.100.200.3 103 broadcast
no frame-relay inverse-arp
router bgp 100
no synchronization
bgp log-neighbor-changes
network 172.31.1.0 mask 255.255.255.0
network 172.31.255.255 mask 255.255.255.255
neighbor 172.31.255.253 remote-as 100
neighbor 172.31.255.253 update-source Loopback0
neighbor 172.31.255.253 route-reflector-client
neighbor 172.31.255.253 next-hop-self
neighbor 172.31.255.253 route-map BGP-RR out
neighbor 172.31.255.254 remote-as 100
neighbor 172.31.255.254 update-source Loopback0
neighbor 172.31.255.254 route-reflector-client
neighbor 172.31.255.254 next-hop-self
neighbor 172.31.255.254 route-map BGP-RR out
no auto-summary
ip route 172.31.255.253 255.255.255.255 63.100.200.3
ip route 172.31.255.254 255.255.255.255 63.100.200.2
access-list 50 permit any
route-map BGP-RR permit 10
match ip address 50
set ip next-hop 172.31.255.255
R2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
interface Loopback0
ip address 172.31.255.254 255.255.255.255
interface Loopback2
ip address 172.31.2.254 255.255.255.0
interface Serial0/0
ip address 63.100.200.2 255.255.255.248
clock rate 2000000
frame-relay map ip 63.100.200.1 201 broadcast
router bgp 100
no synchronization
network 172.31.2.0 mask 255.255.255.0
network 172.31.255.254 mask 255.255.255.255
neighbor 172.31.255.255 remote-as 100
neighbor 172.31.255.255 update-source Loopback0
no auto-summary
ip route 172.31.255.255 255.255.255.255 63.100.200.1
R3 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
interface Loopback0
ip address 172.31.255.253 255.255.255.255
interface Loopback2
ip address 172.31.3.254 255.255.255.0
interface Serial0/0
ip address 63.100.200.3 255.255.255.248
clock rate 2000000
frame-relay map ip 63.100.200.1 301 broadcast
router bgp 100
no synchronization
network 172.31.3.0 mask 255.255.255.0
network 172.31.255.253 mask 255.255.255.255
no auto-summary
Thank you in advance
Solved! Go to Solution.
05-01-2013 12:42 PM
Dear The Sorrow,
let me say again you have only two PVCs and there is no direct PVC between R2 and R3.
So Inverse ARP cannot be of help, at the other end of the unique PVC there is the hub router.
To make things working you don't need an additional PVC, but you need to help each spoke router to solve the other spoke IP WAN address. This is made by using an additional frame-relay map statement in each spoke under the interface configuration.
So try the following:
R2
config t
interface serial 0/0
frame-relay map ip 63.100.200.3 201
R3
config t
interface ser0/0
frame-relay map ip 63.100.200.2 301
After you do this you will be able to ping from spoke to spoke and also networks behind each spoke.
You have a small issue in the forwarding plane. That's all
Hope to help
Giuseppe
05-01-2013 11:21 AM
you are missing additional frame-relay mappings
on R2
you need to map
63.100.200.3 to the same DLCI used to reach the hub router
on R3
the same you need to map
63.100.200.2 to the same DLCI used to reach the hub
Hope to help
Giuseppe
05-01-2013 12:01 PM
I'm actually trying to emulate a situation where management won the battle of network connectivity and thus only two PVCs.
05-01-2013 12:42 PM
Dear The Sorrow,
R2
config t
R3
config t
interface ser0/0
Hope to help
Giuseppe
05-01-2013 12:47 PM
Ah i see. The spokes need to know how to get to their respective parther's ip addresses. I figured they would get to there by hopping across the hub router without an issue. Thanks!
