iBGP or VRRP or Any IGP(OSPF or EIGRP)
Naive
In a Multi homed network when 2 CE's (CE1 and CE2) are connected to 2 PE's (PE1 and PE2). At LAN Side both CE's are connected through a switch. To do Load balancing/Redundancy which protocol would be best. All of 2 CE's and 1 switch are in same AS( As i said this is LAN Side).
** iBGP or VRRP or IGP which protocol is good for which situation.
** Does i also require connection between CE1 and CE2
** Which traffic i can manipulate by this (Inbound or outbound)
0 Replies 0
