02-07-2014 02:24 AM - edited 03-04-2019 10:16 PM
Hey Guys, I have an interesting issue.
Setup: Two 7000 series routers.
(Fictious ips used for example)
Router one: 5.5.5.1
ebgp Peers with Level3 (aprox 474,000 routes)
ebgp Peers with 5.5.5.2
Router two: 5.5.5.2
ebgp peers with Earthlink (aprox 474,000 routes)
ibgp peers with 5.5.5.1
Problem:
The problem is with the ibgp session. Router one will start to recieve routes from router two, I start the session...it starts getting routes in, but but when it hits a certian amount, usually around 200,000, it drops the routes down to around 46,000 routes...and stays there. I cannot for the life of me understand why this is happening. I should add the session isnt dropping, just the routes.
Router two sees 474K routes from both level3 and 5.5.5.1. No problem.
Both routers had 512M of memory. So i figured router1 may be running out, so I upgraded it to a NPE-G1 with 1GB memory. Same problem is happening. And since router2 only has 512MB and is getting full routes fine, I dont think its a memory issue.
Now, if somthing goes wrong with level3, then the routes from 5.5.5.2 start increasing until they reach full routes. Its like im hitting some sort of max limits of routes....which is why i thought memory issue.
I really apreciate help with this as its driving me crazy!
--John
02-10-2014 03:25 PM
Thank you Vishesh! Applied the weight 1000 to both routers, and wham....look at uplink1 now:
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
Level3 4 3356 555075 5302 2823713 30 0 3d16h 473892
Router2 4 xxxx 626863 651686 2837483 0 0 3d12h 477535
Savvis (partial route) 4 3561 79786 5299 2837483 0 0 3d12h 35784
millan: Call me old school, but i prefer to recieve full routes at all sites.
***************** I really apreciate the help you guys, as this had me stumped. ******************
Im curious how this will affect traffic balance with the weight equal now. We try to keep about 70% going through level3 and 30% through earthlink. If level3 fails, 99% goes through level3. We run OSPF on the core routers internally, and use that as well as a script mechnisim to switch which border router it points at for a default, so that in the event router1 or router2 totally goes down, traffic continues to flow.
02-10-2014 03:47 PM
You are welcome!! John, If you want to load-balance, First you have to identify the traffic's destinations and quantity, leaving through each router.
After that you can use route-map between IBGP peers and increase the weight for specific routes; till you get traffic load-balanced between each other the way you want.
Refer to following document, it contains some good case studies about BGP -
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml
And as mentioned in my post earlier following document contains BGP best path selection algorithm -
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
-Vishesh
02-10-2014 03:37 PM
Hi Milan,
I am sorry, I agree with you about the BGP Split-horizon rule, but I didn't mention it in my post. I mentioned "Just like split-horizon rule in EIGRP"
I mean by that is "A local router propagates only the routes that are selected as best to the Ebgp and Ibgp neighbors. However, the router never sends a route back on the same BGP session upon which it was received and selected as a best-path for that prefix. When it picks a neighbor as the best next-hop, the router makes sure that the neighbor is not pointing back to the local router. In order to make this backward destination unreachable, a withdraw message is sent to that neighbor." Which is exactly the case here.
But in Cisco's implemention this rule is bend a little and the route can be advertised to the neighbor who himself is the best-path for the prefix, if that neighbor is part of an update-group and the update-group contains other neighbors to whom we need to send the route. This update-group method is implemented to save memory cycles and processor consumption on the routers.
Second part is the ISP are peering, but that again won't affect route selection process in BGP. As these routers are not advertising the 470K routes back to the ISPs. Also, this is just one of the 470K routes.
Now the question is: Should each of the routers prefer his eBGP neighbor for all prefixes received?
If yes, wouldn't it be easier to ask the providers to send just the default route instead of full BGP tables?
I think John needs to answer this question together with his LAN topology - which router is used as the default GW by the LAN devices?
I agree with all these questions, but I am being a TAC engineer provide resolution based on the problem, I do not make any recommendations on design changes unless explicitly required.
So I think based on John's comment earlier in the post, "I understand BGP will not send an update to a peer if it considers that neighbor a better path, but in that case it causes the problem that when level3 goes down, its missing a lot of routes that were not sent. Somthing isnt right here." increasing the weight would work.
-Vishesh
02-11-2014 02:12 AM
Hi Vishesh,
1) ad "A local router propagates only the routes that are selected as best to the Ebgp and Ibgp neighbors. However, the router never sends a route back on the same BGP session upon which it was received and selected as a best-path for that prefix. When it picks a neighbor as the best next-hop, the router makes sure that the neighbor is not pointing back to the local router. In order to make this backward destination unreachable, a withdraw message is sent to that neighbor." Which is exactly the case here.
I don't think this is the case here.
As Router2 is picking a prefix received from Router1 via iBGP as the best one. So the next-hop is Router1 (using next-hop self), not the Router2 itself (the local router).
BTW, where does this mechanism come from? I've not found it in any BGP RFC, is it Cisco proprietary?
IMHO, the withdrawn is sent because the best path which had been advertised from Router2 to Router1 originally was the eBGP one received from his ISP originally. But now the best path is an iBGP one received from Router1. As iBGP received prefixes should not be advertised via iBGP, Router2 has no path to advertise anymore so the previously advertised path has to be withdrawn, I guess?
2) I agree preferring the eBGP received prefixes has a good sense.
But as shown in the example above, not always.
Possibly it would make a sense to prefer the eBGP prefixes received from the ISP but not those containing the other ISP AS number within the AS_PATH?
So to prefer eBGP prefixes not containing _3356_ on Router2?
And vice versa, to prefer eBGP prefixes not containing _13407_ on Router1?
Best regards,
Milan
02-11-2014 05:49 AM
Hi Milan,
AS 3 AS 4
|ebgp |ebgp
| R1 | | R2 |
| | ibgp | |
| | AS 12 | |
Note in this example that BGP Split Horizon is disabled via route-reflector client, still R2 withdraws the prefixes from R1, if R2 opts to choose R1 as valid best path.
R2
R2#show ip bgp summary | be InQ
12.0.0.1 4 12 32 38 19 0 0 00:00:03 3
24.0.0.4 4 4 26 19 19 0 0 00:04:11 3
R2#show ip bgp | be Net
Network Next Hop Metric LocPrf Weight Path
* i3.3.3.1/32 12.0.0.1 0 100 0 3 i
*> 24.0.0.4 0 0 4 i
* i3.3.3.2/32 12.0.0.1 0 100 0 3 i
*> 24.0.0.4 0 0 4 i
* i3.3.3.3/32 12.0.0.1 0 100 0 3 i
*> 24.0.0.4 0 0 4 i
R2#
*Mar 1 00:36:40.835: BGP(0): 24.0.0.4 rcvd UPDATE w/ attr: nexthop 24.0.0.4, origin i, metric 0, path 4
*Mar 1 00:36:40.835: BGP(0): 24.0.0.4 rcvd 3.3.3.3/32
*Mar 1 00:36:40.835: BGP(0): 24.0.0.4 rcvd 3.3.3.2/32
*Mar 1 00:36:40.839: BGP(0): 24.0.0.4 rcvd 3.3.3.1/32
*Mar 1 00:36:40.843: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.1/32 -> 24.0.0.4(main) to main IP table
*Mar 1 00:36:40.843: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.2/32 -> 24.0.0.4(main) to main IP table
*Mar 1 00:36:40.847: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.3/32 -> 24.0.0.4(main) to main IP table
R2#
*Mar 1 00:36:40.847: BGP(0): 12.0.0.1 NEXT_HOP is set to self for net 3.3.3.1/32,
*Mar 1 00:36:40.851: BGP(0): 12.0.0.1 send UPDATE (format) 3.3.3.1/32, next 12.0.0.2, metric 0, path 4
*Mar 1 00:36:40.851: BGP(0): 12.0.0.1 NEXT_HOP is set to self for net 3.3.3.2/32,
*Mar 1 00:36:40.855: BGP(0): 12.0.0.1 send UPDATE (prepend, chgflags: 0x820) 3.3.3.2/32, next 12.0.0.2, metric 0, path 4
*Mar 1 00:36:40.855: BGP(0): 12.0.0.1 NEXT_HOP is set to self for net 3.3.3.3/32,
*Mar 1 00:36:40.855: BGP(0): 12.0.0.1 send UPDATE (prepend, chgflags: 0x820) 3.3.3.3/32, next 12.0.0.2, metric 0, path 4
Event - routes from 24.0.0.4 have been advertised with a longer AS-Path, R2 chooses R1 as the best path and withdraws the prefixes from R1.
12.0.0.1 4 12 38 46 25 0 0 00:06:21 3
24.0.0.4 4 4 34 25 25 0 0 00:10:29 3
R2#show ip bgp
*>i3.3.3.1/32 12.0.0.1 0 100 0 3 i
* 24.0.0.4 0 0 4 4 3 i
*>i3.3.3.2/32 12.0.0.1 0 100 0 3 i
*>i3.3.3.3/32 12.0.0.1 0 100 0 3 i
R2#
*Mar 1 00:37:10.943: BGP(0): 24.0.0.4 rcvd UPDATE w/ attr: nexthop 24.0.0.4, origin i, metric 0, path 4 4 3
*Mar 1 00:37:10.943: BGP(0): 24.0.0.4 rcvd 3.3.3.3/32
*Mar 1 00:37:10.947: BGP(0): 24.0.0.4 rcvd 3.3.3.2/32
*Mar 1 00:37:10.947: BGP(0): 24.0.0.4 rcvd 3.3.3.1/32
*Mar 1 00:37:10.951: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.1/32 -> 12.0.0.1(main) to main IP table
*Mar 1 00:37:10.951: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.2/32 -> 12.0.0.1(main) to main IP table
*Mar 1 00:37:10.955: BGP(0): Revise route installing 1 of 1 routes for 3.3.3.3/32 -> 12.0.0.1(main) to main IP table
R2#
*Mar 1 00:37:10.955: BGP(0): 12.0.0.1 send unreachable 3.3.3.1/32
*Mar 1 00:37:10.959: BGP(0): 12.0.0.1 send UPDATE 3.3.3.1/32 -- unreachable
*Mar 1 00:37:10.959: BGP(0): 12.0.0.1 send UPDATE 3.3.3.2/32 -- unreachable
*Mar 1 00:37:10.959: BGP(0): 12.0.0.1 send UPDATE 3.3.3.3/32 -- unreachable
R2#show run | se router bgp
router bgp 12
no synchronization
bgp log-neighbor-changes
neighbor 12.0.0.1 remote-as 12
neighbor 12.0.0.1 route-reflector-client
neighbor 12.0.0.1 next-hop-self
neighbor 24.0.0.4 remote-as 4
neighbor 24.0.0.4 prefix-list n0thing out
no auto-summary
R1
R1#show ip bgp summary | be InQ
12.0.0.2 4 12 51 42 4 0 0 00:10:34 3
13.0.0.3 4 3 29 27 4 0 0 00:24:19 3
R1#show ip bgp
* i3.3.3.1/32 12.0.0.2 0 100 0 4 i
*> 13.0.0.3 0 0 3 i
* i3.3.3.2/32 12.0.0.2 0 100 0 4 i
*> 13.0.0.3 0 0 3 i
* i3.3.3.3/32 12.0.0.2 0 100 0 4 i
*> 13.0.0.3 0 0 3 i
After Event
R1#
BGP(0): 12.0.0.2 rcv UPDATE about 3.3.3.1/32 -- withdrawn
BGP(0): 12.0.0.2 rcv UPDATE about 3.3.3.2/32 -- withdrawn
BGP(0): 12.0.0.2 rcv UPDATE about 3.3.3.3/32 -- withdrawn
12.0.0.2 4 12 46 38 4 0 0 00:06:54 0
13.0.0.3 4 3 25 23 4 0 0 00:20:39 3
R1#show ip bgp
*> 3.3.3.1/32 13.0.0.3 0 0 3 i
*> 3.3.3.2/32 13.0.0.3 0 0 3 i
*> 3.3.3.3/32 13.0.0.3 0 0 3 i
So, believe me or not what I had explained is correct. And I do not read rfc's, but 1 thing I am sure of is this is how it works, on Cisco platforms, I have never tested this on other platforms.
-Vishesh
02-14-2014 05:14 AM
Hi Vishesh,
you are right.
I made a simple test with eBGP in my lab it the withdrawn was also sent!
So split horizon with poison-reverse was implemented for BGP by Cisco in fact?
I found this feature also mentioned in this Cisco Press book:
http://www.ciscopress.com/store/bgp-design-and-implementation-9781587051098
on page 283, e.g.
Interestingly no other BGP book/RFC mentioned that.
Good to discuss here to learn something new!
Milan
