02-29-2012 01:26 AM - edited 03-04-2019 03:28 PM
The router is Cisco 7606 (RSP-720-3CXL-10GE is the supervisor).
The router does not return TTL Message. (traceroute command behind this router does not work).
Tracing route to abv.bg [194.153.145.104]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 95.87.0.49
2 * * * Request timed out.
3 5 ms 2 ms 3 ms 145.128.158.95-rev.novatelbg.net [95.158.128.145]
4 5 ms 5 ms 11 ms 145.236.236.64
5 14 ms 5 ms 7 ms novatel.bix.bg [193.169.198.109]
6 5 ms 4 ms 5 ms netinfo.bix.bg [193.169.198.168]
7 5 ms 4 ms 4 ms abv.bg [194.153.145.104]
Trace complete.
02-29-2012 02:00 AM
Not clear what is the problem. From trace I see that it is reaching final destination. Why do you expect TTL Expire message to arrive?
Nik
02-29-2012 02:05 AM
Ok. Think as traceroute throw the router does not work. ("2 * * * Request timed out.", here should be the router ip address). Ping to router is OK.
02-29-2012 02:26 AM
Ok Got it -- thnaks.
Possibly it sends reply but with some delay - that is why answer considered as timed out. Do you see any delay pinging that router? Can you please try pinging that with time 1 in ping to lower response time expected.
Also do you see that host dropping traceback ICMP continiously or on random tries?
Have you check the CPU load on it? (show proc cpu sort and show proc cpu history)
Nik
02-29-2012 02:34 AM
C:\Documents and Settings\TrakiaCable>ping 95.87.0.1 -t
Pinging 95.87.0.1 with 32 bytes of data:
Reply from 95.87.0.1: bytes=32 time=2ms TTL=254
Reply from 95.87.0.1: bytes=32 time=3ms TTL=254
Reply from 95.87.0.1: bytes=32 time=5ms TTL=254
Reply from 95.87.0.1: bytes=32 time=6ms TTL=254
Reply from 95.87.0.1: bytes=32 time=9ms TTL=254
Reply from 95.87.0.1: bytes=32 time<1ms TTL=254
Reply from 95.87.0.1: bytes=32 time=1ms TTL=254
Reply from 95.87.0.1: bytes=32 time=43ms TTL=254
Reply from 95.87.0.1: bytes=32 time=8ms TTL=254
Ping statistics for 95.87.0.1:
Packets: Sent = 15, Received = 15, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 43ms, Average = 6ms
sz-edge1#sho processes cpu | exclude 0.00%__0.00%__0.00%
CPU utilization for five seconds: 7%/2%; one minute: 9%; five minutes: 9%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 100 48057 2 0.07% 0.01% 0.00% 0 Load Meter
3 268 861 311 0.07% 0.09% 0.06% 1 SSH Process
7 1555360 91579 16983 0.00% 1.38% 1.10% 0 Check heaps
12 97516 1003195 97 0.00% 0.03% 0.04% 0 ARP Input
13 208 251720 0 0.00% 0.01% 0.00% 0 ARP Background
26 24 234349 0 0.07% 0.00% 0.00% 0 IPC Deferred Por
28 34200 744806 45 0.00% 0.01% 0.00% 0 IPC Seat Manager
61 2476 240211 10 0.00% 0.01% 0.00% 0 TTY Background
137 84 240099 0 0.07% 0.00% 0.00% 0 Heartbeat Proces
161 65504 181319 361 0.00% 0.02% 0.00% 0 BGP Router
164 50724 8275 6129 0.00% 0.01% 0.00% 0 Per-minute Jobs
165 528 240352 2 0.00% 0.03% 0.02% 0 Per-Second Jobs
196 364 7436175 0 0.00% 0.02% 0.00% 0 ACE Tunnel Task
232 320 7435337 0 0.00% 0.01% 0.00% 0 IP ARP Retry Age
233 7315316 129181230 56 3.03% 2.96% 2.96% 0 IP Input
240 1117480 6981 160074 0.00% 0.76% 0.85% 0 BGP Scanner
270 712 30294279 0 0.15% 0.11% 0.10% 0 Ethernet Msec Ti
274 396 7435969 0 0.00% 0.01% 0.00% 0 IPAM Manager
337 996 64081 15 0.00% 0.01% 0.00% 0 CDP Protocol
341 194864 3642995 53 0.23% 0.19% 0.17% 0 ADJ resolve proc
347 552 474885 1 0.07% 0.01% 0.00% 0 TCP Timer
348 5584 23695 235 0.00% 0.01% 0.00% 0 TCP Protocols
397 180 342205 0 0.07% 0.00% 0.00% 0 FM core
412 97160 120142 808 0.07% 0.06% 0.05% 0 HIDDEN VLAN Proc
528 512 45394 11 0.00% 0.02% 0.00% 0 RIP Timers
531 543420 6810671 79 0.00% 0.19% 0.22% 0 Port manager per
591 324292 6812868 47 0.23% 0.15% 0.15% 0 IGMP Input
592 880 4786899 0 0.00% 0.04% 0.05% 0 PIM Process
593 756 2396940 0 0.07% 0.02% 0.00% 0 Mwheel Process
594 8668 1220566 7 0.07% 0.01% 0.00% 0 MRIB Trans
597 752 11934184 0 0.07% 0.05% 0.05% 0 MFIB_mrib_write
598 13056 340348 38 0.07% 0.00% 0.00% 0 MFIB_mrib_read
607 34548 492738 70 0.00% 0.01% 0.00% 0 SNMP ENGINE
DF bit unreachables All other unreachables
Interval (millisecond) 1 1
Interface # DF bit unreachables # All other unreachables
GigabitEthernet1/43 0 0
GigabitEthernet5/3 0 0
Vlan304 0 5
Vlan1001 0 2120
Vlan1402 0 132352
Vlan1500 0 0
Vlan1501 0 0
Vlan2402 0 927
Vlan2414 0 14
Vlan3021 0 0
02-29-2012 02:44 AM
Ok,
Just one more test. Can you try to do the traceroutes and on the router sz-edge1 where they fail to be sent back pls do
"show ip traffic | i time exceeded" - those are counters for expired TTL icmp sent. Want to check if those grow or stay stale.
One more thing - can you also check config on this router interface which should respond ro these ICMP (it is incoming L3 int). See if there are any "no ip unreachable" or "no ip redirect" configured.
Nik
02-29-2012 02:49 AM
As I see it is sporadic:
Tracing route to 95.87.0.202 over a maximum of 30 hops
1 1 ms <1 ms <1 ms 95.87.0.49
2 * * <1 ms edge-sz.trakiacable.net [95.87.0.1]
3 35 ms 33 ms 33 ms 95.87.0.202
Trace complete.
sz-edge1#show ip traffic | i time exceeded
0 info reply, 6888 time exceeded, 0 parameter problem
interface GigabitEthernet1/1
switchport
switchport access vlan 1001
switchport mode access
switchport nonegotiate
interface GigabitEthernet1/2
switchport
interface GigabitEthernet1/3
switchport
interface GigabitEthernet1/4
switchport
interface GigabitEthernet1/5
switchport
interface GigabitEthernet1/6
switchport
interface GigabitEthernet1/7
switchport
interface GigabitEthernet1/8
switchport
shutdown
interface GigabitEthernet1/9
switchport
interface GigabitEthernet1/10
switchport
interface GigabitEthernet1/11
switchport
interface GigabitEthernet1/12
switchport
interface GigabitEthernet1/13
no ip address
shutdown
interface GigabitEthernet1/14
no ip address
shutdown
interface GigabitEthernet1/15
no ip address
shutdown
interface GigabitEthernet1/16
no ip address
shutdown
interface GigabitEthernet1/17
no ip address
shutdown
interface GigabitEthernet1/18
no ip address
shutdown
interface GigabitEthernet1/19
no ip address
shutdown
interface GigabitEthernet1/20
no ip address
shutdown
interface GigabitEthernet1/21
no ip address
shutdown
interface GigabitEthernet1/22
no ip address
shutdown
interface GigabitEthernet1/23
no ip address
shutdown
interface GigabitEthernet1/24
no ip address
shutdown
interface GigabitEthernet1/25
no ip address
shutdown
interface GigabitEthernet1/26
no ip address
shutdown
interface GigabitEthernet1/27
no ip address
shutdown
interface GigabitEthernet1/28
no ip address
shutdown
interface GigabitEthernet1/29
no ip address
shutdown
interface GigabitEthernet1/30
no ip address
shutdown
interface GigabitEthernet1/31
no ip address
shutdown
interface GigabitEthernet1/32
no ip address
shutdown
interface GigabitEthernet1/33
no ip address
shutdown
interface GigabitEthernet1/34
no ip address
shutdown
interface GigabitEthernet1/35
no ip address
shutdown
interface GigabitEthernet1/36
no ip address
shutdown
interface GigabitEthernet1/37
switchport
switchport trunk allowed vlan 2414
switchport mode trunk
speed 1000
interface GigabitEthernet1/38
no ip address
shutdown
interface GigabitEthernet1/39
no ip address
shutdown
interface GigabitEthernet1/40
no ip address
shutdown
interface GigabitEthernet1/41
no ip address
shutdown
interface GigabitEthernet1/42
no ip address
shutdown
interface GigabitEthernet1/43
ip address x.x.x.x y.y.y.y
ip pim dense-mode
interface GigabitEthernet1/44
no ip address
ip pim dense-mode
interface GigabitEthernet1/45
switchport
switchport trunk allowed vlan 1501
interface GigabitEthernet1/46
switchport
switchport access vlan 1500
switchport trunk native vlan 1500
switchport trunk allowed vlan 1500,2896
interface GigabitEthernet1/47
switchport
switchport trunk allowed vlan 3021
interface GigabitEthernet1/48
switchport
interface GigabitEthernet5/1
switchport
switchport trunk allowed vlan 304
interface GigabitEthernet5/2
no ip address
shutdown
interface GigabitEthernet5/3
ip pim dense-mode
interface TenGigabitEthernet5/4
description Novatel
switchport
switchport trunk allowed vlan 1402,2402,2896
interface TenGigabitEthernet5/5
no ip address
shutdown
interface Vlan1
no ip address
interface Vlan101
no ip address
shutdown
interface Vlan304
interface Vlan1001
interface Vlan1402
interface Vlan1500
ip pim dense-mode
interface Vlan1501
ip unnumbered Vlan1500
ip pim sparse-mode
ip igmp static-group z.z.z.z
ip igmp access-group BBCMulticast
interface Vlan2402
interface Vlan2414
interface Vlan2896
no ip address
no ip igmp snooping
interface Vlan3021
ip pim dense-mode
ip igmp join-group z.z.z.z
ip igmp query-max-response-time 5
ip igmp query-interval 10
no ip igmp snooping
02-29-2012 03:06 AM
SO basically this router is sending TTL expired packets:
Did you try to do multiple traces through this router to see if that umber is growing?
It seems that due to some internal CPU realization the packet is just got delaid and initiator not receiving it in time count that as drop. To check it in more detail we may need to setup SPAN on ingress port to see the time when trace ICMP is coming to this port and when ICMP reply for TTL expired is sent to consider it further.
Nik
03-05-2012 06:53 AM
I found this while examining cef:
sz-edge1#sh cef interface vlan 2402
Vlan2402 is up (if_number 84)
Corresponding hwidb fast_if_number 84
Corresponding hwidb firstsw->if_number 84
Internet address is x.x.x.x/30
ICMP redirects are never sent
IP unicast RPF check is disabled
Output features: HW Shortcut Installation
IP policy routing is disabled
BGP based policy accounting on input is disabled
BGP based policy accounting on output is disabled
Hardware idb is Vlan2402
Fast switching type 28, interface type 147
IP CEF switching enabled
IP CEF switching turbo vector
IP Null turbo vector
IP prefix lookup IPv4 mtrie generic
Input fast flags 0x0, Output fast flags 0x0
ifindex 83(83)
Slot unknown (255) Slot unit 2402 VC -1
IP MTU 1500
Is it relevant to this problem ?
