ICMPV6, Microsoft Vista
dvanhoyweghen
Our client has installed Microsoft Vista,
But this Pc is sending now 2000 packets/sec over the lan as type "ICMPv6 Multicast listener Report Message v2".
What can we do as action on our Cisco switches ???
regards
5 Replies 5
purohit_810
Level 5
Level 5
In Local area connection property there are IPV6 enabled.
Disable that.
It will be stop. RUN purely on IPV4.
Dharmesh
Your answer is not clear for me !
What I have to stop ?
My problem is that when You install a PC with windows Vista on a IPV4 LAN ,this Pc is sending more than 2000 IPv6 packets/sec over the LAN (ICMPv6 Multicast listener Report Message V2).
How can I stop this ???
What can I configured on the cisco router to stop this ??
regards
Dirk
Edison Ortiz
What model of switches ?
Thanks for the response!
The switchs our client used are : C2950, C2970 and C3750
regards
Dirk
I can only offer a suggestion for the 3750 and that is configuring MLD snooping in order to control the flood
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12237se/scg/swv6mld.htm
As for the 2950 and 2970, they don't have IPv6 support so in general, you recommend disabling the service in the Vista machines as its the root of the problem.
