IFFCO Remote Server Not Access
salman-ahmad
We have one of our customer named IFFCO. They have facing problem that they won't able to access there remote server "10.1.1.13" from Regional branches like MUL R.O,HYD R.O but it can access from Factory router and from Vlan1 and Vlan2. I have attached the diagram and configuration of HO router, L3 switch.
Your kind response will solve this problem
regards
Salman
a.alekseev
Level 7
Level 7
Hi, Salman Ahmad
You should redesign the vpn connection between ASA and remote peer 213.42.236.44
Your crypto acl "iffcosts_list" must be reconsidered on both sides.
[Pls RATE if HELPS]
Describe me briefly about crypto acl on
both side.
What do you mean by both sides in detail?
regards
Salman
no access-list iffcosts_list extended permit ip host 192.168.2.15 192.168.10.0 255.255.255.0
no access-list iffcosts_list extended permit ip host 192.168.2.13 host 10.1.1.20
no access-list iffcosts_list extended permit ip 192.168.0.0 255.255.0.0 host 10.1.6.11
no access-list iffcosts_list extended permit ip 192.168.3.0 255.255.255.0 192.168.10.0 255.255.255.0
no access-list iffcosts_list extended permit ip 192.168.1.0 255.255.255.0 192.168.10.0 255.255.255.0
no access-list iffcosts_list extended permit ip 192.168.2.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list iffcosts_list extended permit ip 192.168.0.0 255.255.0.0 10.1.0.0 255.255.0.0
access-list iffcosts_list extended permit ip 192.168.0.0 255.255.0.0 192.168.10.0 255.255.255.0
no access-list iffcosts_list extended permit tcp 192.168.2.0 255.255.255.0 host 10.1.1.20 eq lotusnotes
on your peer must have mirror crypto acl
access-list peer_list extended permit ip 10.1.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list peer_list extended permit ip 192.168.10.0 255.255.255.0 192.168.0.0 255.255.0.0
