Hi Expert,
I have a Cisco Router and i want to enable IPTV multicast stream from interface VLAN 100. The aim is to replace my ISP box by a cisco router,
I have identified an issue
With Wireshark I have a trace with the ISP Box and we can see IGMP Report (Join) and IGMP Leave sent to the WAN with right destination address 232.X.X.X.
When i use my router with an igmp proxy i have IGMP Report with destination to 0.0.0.0 and no leave message
Please have a look at the attached screen shot
Hereafter my cisco igmp proxy config
interface Loopback0
ip address 192.168.2.1 255.255.255.0
ip pim dense-mode
ip igmp helper-address udl GigabitEthernet0/0.100
ip igmp proxy-service
interface GigabitEthernet0/0.100
description SUBIF BYTEL IPTV VOIP PFS
encapsulation dot1Q 100
ip dhcp client client-id hex 0037B755E368
ip dhcp client class-id byteliad_private
ip address dhcp
ip pim sparse-mode
ip nat outside
no ip virtual-reassembly in
ip igmp unidirectional-link
no cdp enable
interface GigabitEthernet0/1
description IF LOCAL NETWORK 1
ip pim sparse-mode
ip nat inside
ip policy route-map ISPSelect
ip igmp mroute-proxy Loopback0
duplex auto
speed auto
Can you please help to solve this blocking issue.
Vincent
