Illegal HDLC error
alister9000
hi everyone,
so i just got a t1 line and when i configure the IP address i get this error message
Illegal HDLC serial type code 972, PC=0x213FEF40
before this error comes, i am able to ping for about 5 seconds, after the error the port shuts down.
now, i found out that this is because the router received a piece of information and it doesnt know what to do with it, and it has to do with encapsulation.
im a little green about cisco routers, so i was wondering if someone can help me figure out how to fix this. I talk with the isp and they told me that there's nothing they can do to help. they provided me with an adtran t1 device so i can connect it to the ethernet port but i dont have any ethernet port left on the router so i need to use the t1 port.
is there anyway i can configure the router to ignore that error? because im assuming that if im beeing able to ping for a couple seconds until that error it means that outside that error everything is fine.
i dont know if it matters but i have a cisco 1921 router..
thanks,
You'll need to contact the ISP to get the appropriate settings. They have FR configured on their router and that should translate to the Cisco with no issues. The fact that the interface comes up and stays up is proof enough that FR encapsulation is used. The only thing you haven't done is change the encapsulation type:
int s0/0/0.500
encapsulat frame-relay ietf
HTH, John *** Please rate all useful posts ***
23 Replies 23
paolo bevilacqua
The T1 circuit is likely faulty.
Since the 1921 has two ethernet ports, have them bring in the interface converter, so whaever circuit problem will be ISP and telco responsibility to solve.
After the circuit will be working you will be able to connect the router T1 directly if you want.
thank you for the reply,
i connected a computer directly into the adtran that they provided and configured the LAN ip address that they gave me and it worked fine. so i dont think its a faulty circuit.
i didnt know there was such a thing as an interface converter, how does that work? is it to connect the ethernet into the t1 port?
John Blakley
David,
If you're connecting a patch cable from the CSU/DSU (Adtran) into the WIC that is also a CSU/DSU, you'll probably see this error. Can you post "sh inventory"?
HTH,
John
j.blakley wrote:
David,
HTH,
John
thank you for the reply John,
i am connecting the cable comming from the MPOE to the T1 CSU/DSU port.
and i just received an email from the ISP saying that the protocol is down and that i should contact support about it, (which i already did and told me that they cant help).
here is the sh inventory output
Router#sh inventory
NAME: "CISCO1921/K9 chassis", DESCR: "CISCO1921/K9 chassis"
PID: CISCO1921/K9      , VID: V04 , SN: FGL161322ZC
NAME: "WAN Interface Card - HWIC CSU/DSU on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC CSU/DSU"
PID: HWIC-1DSU-T1      , VID: V02 , SN: FOC16093PUB
David,
I'm assuming that you are connecting the cable directly from the smartjack to the WIC on the router and bypassing the Adtran? Can you post your serial configuration? (Mask out addresses) Also, post "sh controllers".
John
j.blakley wrote:
David,
John
Yes that is how im connecting it.
I changed the ip address on this output.
interface Serial0/0/0
ip address 1.1.1.1 255.255.255.252
also i was able to telnet into the adtran and got this i dont know if it will be of any help, i dont quite understand it ..
interface fr 1.500 point-to-point
  frame-relay interface-dlci 500
  no lldp send-and-receive
here is the sh controllers output:
Router#sh controllers
Embedded engine is not enabled
Interface GigabitEthernet0/0
= Hardware =
Hardware is PLATFORM SGMII INTERFACE
HWIDB: 309A3978, INSTANCE: 309A4680, FASTSEND: 2114A740, MCI_INDEX: 0
Route Cache Flag: 11
= Media  RJ45 =
Media Change Count: 1
PORT IPD Registers:
        BP_PAGE_CNT: 0x0000000000000001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
        RXX_INT_REG: 0x0000000000000000, RXX_INT_EN : 0x0000000000000000
        PRTX_CFG   : 0x000000000000300F, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_FRM_MIN: 0x0000000000000000
        RXX_FRM_MAX: 0x0000000000000000, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x0000000000000077
        RXX_FRM_CHK: 0x00000000000003BA, RXX_JABBER : 0x0000000000002580
        RXX_DECISIO: 0x0000000000000018, RXX_UDD_SKI: 0x0000000000000000
        RXX_STATS_C: 0x0000000000000000, RXX_IFG    : 0x0000000000000008
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000CB57E8
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000013333
        RXX_STAT_DR: 0x0000000000000000, RXX_STATS_B: 0x0000000000000000
        SMACX      : 0x0000442B03A288C0
        TXX_SGMII_C: 0x0000000000000001, TXX_CTL    : 0x0000000000000003
        RX_PRTS    : 0x0000000000000004, RX_BP_DROP : 0x0000000000000002
        RX_BP_ON   : 0x0000000000000040, RX_BP_OFF  : 0x0000000000000010
        TXX_PAU_PKT: 0x0000000000000060, TXX_MIN_PKT: 0x000000000000003B
        TXX_PAU_PKI: 0x0000000000000010, TXX_SOFTPAU: 0x0000000000000000
        TXX_PAU_TGO: 0x0000000000000000, TXX_PAU_ZRO: 0x0000000000000001
        INF_MODE   : 0x0000000000000032, TX_PRTS    : 0x0000000000000004
        TX_IFG     : 0x0000000000000048, TX_JAM     : 0x00000000000000EE
        TX_COL_ATMP: 0x0000000000000010, TX_PAU_DMAC: 0x00000180C2000001
        TX_PAU_TYPE: 0x0000000000008808, TX_OVR_BP  : 0x0000000000000101
        TX_BP      : 0x0000000000000000, TX_CORRUPT : 0x000000000000000F
        RX_PRT_INFO: 0x0000000000000000, GMX_STAT_BP: 0x0000000000000000
        TX_INT_REG : 0x0000000000000000, TX_INT_EN  : 0x0000000000000000
        ADR_CAM0   : 0x0000000000000044
        ADR_CAM1   : 0x000000000000002B
        ADR_CAM2   : 0x0000000000000003
        ADR_CAM3   : 0x00000000000000A2
        ADR_CAM4   : 0x0000000000000088
        ADR_CAM5   : 0x00000000000000C0
        ADR_CTL    : 0x000000000000000D, CAM_EN     : 0x00000000000000FF
        TXX_STAT0  : 0x0000000000000000, TXX_STAT1  : 0x0000000000000000
        TXX_STAT2  : 0x000000012DC097EF, TXX_STAT3  : 0x0000000000CBEA37
        TXX_STAT4  : 0x00214FBB00000000, TXX_STAT5  : 0x00107C0700694D44
        TXX_STAT6  : 0x0006301000040868, TXX_STAT7  : 0x00000000002698B9
        TXX_STAT8  : 0x000038380000020D, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        MRX_CTL_REG: 0x0000000000001140, MRX_STS_REG: 0x000000000000017C
        RXX_STA_REG: 0x0000000000001CC7, RXX_SYN_REG: 0x0000000000000003
        TXX_STA_REG: 0x0000000000000064, SGMX_AN_ADV: 0x0000000000001801
        SGMX_AN_ADV: 0x000000000000D801, MISC_CTL   : 0x0000000000000000
        ANX_ADV_REG: 0x0000000000000060, ANX_LP_ABIL: 0x000000000000D000
        ANX_RESULTS: 0x0000000000000017, ANX_EXT_ST : 0x000000000000C000
        LNX_TMR_CNT: 0x00000000000002FD, TX_RXX_PLRT: 0x0000000000000000
        INT_REG    : 0x0000000000000000, INT_EN_REG : 0x0000000000000000
        LOG_ANL_REG: 0x0000000000000000, ANX_ADV_REG: 0x0000000000000060
        ANX_LP_ABIL: 0x000000000000D000, ANX_RSL_REG: 0x0000000000000017
        ANX_EXT_ST : 0x000000000000C000, LNX_TMR_CNT: 0x00000000000002FD
        MISCX_CTL: 0x0000000000001001
==============PIP Statistics================
        PIP_RX_NO_ERR = 0, PIP_PARTIAL_ERR = 0
        PIP_JABBER_ERR = 0, PIP_OVER_FCS_ERR = 0
        PIP_OVER_ERR = 0, PIP_ALIGN_ERR = 0
        PIP_UNDER_FCS_ERR = 0, PIP_GMX_FCS_ERR = 0
        PIP_UNDER_ERR = 0, PIP_EXTEND_ERR = 0
        PIP_PIP_L2_MAL_HDR = 0
        pip_rx_no_particle = 0, pip_undef_err = 0
        pip_rx_no_buf_start = 0
PHY REGISTERS:
        Display for CRC check for page:6
        PACKET_GENERATION reg_addr: 16: 0x0010
        CRC COUNTERS reg_addr: 17: 0xFF00
        page number:0
        Copper Contrl @ reg_addr: 0: 0x1140
        Copper Status @ reg_addr: 1: 0x796D
        PHY Idf1 @ reg_addr: 2: 0x0141
        PHY Idf2 @ reg_addr: 3: 0x0C97
        Autoneg Adv @ reg_addr: 4: 0x0DE1
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0xC1E1
        Autoneg Exp @ reg_addr: 6: 0x000D
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2801
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x4944
        1000B-T Ctr @ reg_addr: 9: 0x0E00
        1000B-T St @ reg_addr: 10: 0x3800
        Copper Ext St @ reg_addr: 15: 0x3000
        Copper Specific Ctl1 @ reg_addr: 16: 0x6060
        Copper Specific St1 @ reg_addr: 17: 0xAC08
        Copper Interrupt En @ reg_addr: 18: 0x0000
        Copper Specific St2 @ reg_addr: 19: 0x0000
        Copper Rcv Er Ctr @ reg_addr: 21: 0x0000
        Copper Specific Ctl2 @  reg_addr: 26: 0x8040
        page number:1
        Fiber Contrl @ reg_addr: 0: 0x1140
        Fiber Status @ reg_addr: 1: 0x794D
        Autoneg Adv @ reg_addr: 4: 0x0060
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x0000
        Autoneg Exp @ reg_addr: 6: 0x0004
        Autoneg Nx Pg Tx @ reg_addr: 7: 0x2001
        Autoneg Lk Prt Nx Pg @ reg_addr: 8: 0x0000
        Fiber Ext St @ reg_addr: 15: 0x3000
        Fiber Specific Ctl1 @ reg_addr: 16: 0x0000
        Fiber Specific St1 @ reg_addr: 17: 0x0018
        Fiber Interrupt En @ reg_addr: 18: 0x0000
        Fiber Specific St2 @ reg_addr: 19: 0x0000
        Fiber Rcv Er Ctr @ reg_addr: 21: 0x0000
        Fiber Specific Ctl2 @  reg_addr: 26: 0x8085
        page number:2
        MAC Contrl @ reg_addr: 0: 0x1040
        MAC Specific Ctl1 @ reg_addr: 16: 0x0288
        MAC Specific St1 @ reg_addr: 17: 0x0440
        MAC Interrupt En @ reg_addr: 18: 0x0000
        MAC Specific St2 @ reg_addr: 19: 0x0000
        MAC Specific Ctl2 @  reg_addr: 26: 0x0005
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 245, TX_TAIL: 245
TX_MIN_SIZE: 32, TX_MAX_SIZE: 512, TX_CURRENT_SIZE: 128
RX STARVES: 0
Software MAC Address Filter (hash:length/addr/mask/hits)
  0x000:  0  ffff.ffff.ffff  0000.0000.0000    190280
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000     38479
  0x0C0:  1  0180.c200.0002  0000.0000.0000         0
  0x0C3:  0  442b.03a2.88c0  0000.0000.0000         0
  0x0C5:  0  0180.c200.0007  0000.0000.0000         0
  Software filtered frames: 472239
  Unicast overflow mode: 0
  Multicast overflow mode: 1
  Promiscuous mode: 0
  Total Number of CAM entries: 1
Port Stopped: N
Internal Loopback Set: N
Interface GigabitEthernet0/1
= Hardware =
HWIDB: 309B3020, INSTANCE: 309B3D80, FASTSEND: 2114A740, MCI_INDEX: 0
= Media  RJ45 =
PORT IPD Registers:
        BP_PAGE_CNT: 0x0000000000020001, BP_CNTS_PRX: 0x0000000000000000
GMX Registers:
        PRTX_CFG   : 0x0000000000003005, RXX_FRM_CTL: 0x000000000000007F
        RXX_DECISIO: 0x0000000000000018, RXX_FRM_CTL: 0x000000000000007F
        RXX_PAU_DRP: 0x0000000000000000, RXX_STATS_P: 0x0000000000CDA5D0
        RXX_STAT_CT: 0x0000000000000000, RXX_STATS_D: 0x0000000000000000
        SMACX      : 0x0000442B03A288C1
        ADR_CAM5   : 0x00000000000000C1
        TXX_STAT2  : 0x00000000711C1E80, TXX_STAT3  : 0x0000000000C4D762
        TXX_STAT4  : 0x00253B6400000000, TXX_STAT5  : 0x0010AE870081FCE5
        TXX_STAT6  : 0x0006FCC200025501, TXX_STAT7  : 0x0000000000039ECF
        TXX_STAT8  : 0x00003D08000017EA, TXX_STAT9  : 0x0000000000000000
PCS Registers:
        SGMX_AN_ADV: 0x000000000000D401, MISC_CTL   : 0x0000000000000000
        ANX_RESULTS: 0x000000000000000F, ANX_EXT_ST : 0x000000000000C000
        ANX_LP_ABIL: 0x000000000000D000, ANX_RSL_REG: 0x000000000000000F
        MISCX_CTL: 0x0000000000001005
        PIP_LENGTH_ERR = 0, PIP_DAT_ERR = 0
        PIP_SKIP_ERR = 0, PIP_NIBBLE_ERR = 0
        PIP_UNKNOWN_ERR_14 = 0, PIP_UNKNOWN_ERR_15 = 0
        PIP_PIP_FCS = 0, PIP_PIP_SKIP_ERR = 0
PHY REGISTERS:
        page number:0
        Autoneg Lnk Ptr abty @ reg_addr: 5: 0x45E1
        Autoneg Exp @ reg_addr: 6: 0x0005
        1000B-T St @ reg_addr: 10: 0x4000
        Copper Specific St1 @ reg_addr: 17: 0x6F48
        page number:1
        page number:2
TX_COUNT: 0, TX_LIMITED: 0, TX_HEAD: 324, TX_TAIL: 324
RX STARVES: 0
  0x000:  0  ffff.ffff.ffff  0000.0000.0000         0
  0x0C0:  0  0100.0ccc.cccc  0000.0000.0000         0
  0x0C2:  0  442b.03a2.88c1  0000.0000.0000         0
  Software filtered frames: 0
  Promiscuous mode: 0
Port Stopped: N
Interface Serial0/0/0
Hardware is SCC with Integrated FT1 CSU/DSU module
Clock Freq detected Rx clk/Tx clk 1472561/1472561 (+-10%)
idb at 0x309E69BC, driver data structure at 0x284E2DE0
wic_info 0x309ED8D8
WIC Serial Global Registers: (0x10490000)
sti_errintr_en      (0004): 0x00000000  scc_ctrl_regs       (1004): 0x0020
mgmt_intr_status    (1010): 0x0010      netio_intr_status   (1012): 0x0000
mgmt_intr_enable    (1020): 0x00CA      netio_intr_enable   (1022): 0x0001
timer_0_7_enable    (1024): 0x0000      timer_16_19_enable  (1026): 0x0000
timer_0_1_program   (1030): 0x0000      timer_2_3_program   (1032): 0x0000
timer_4_5_program   (1034): 0x0000      timer_6_7_program   (1036): 0x0000
timer_16_program    (1040): 0x0000      timer_17_program    (1042): 0x0000
timer_18_program    (1044): 0x0000      timer_19_program    (1046): 0x0000
WIC Serial SCC Registers: (0)
ch_mode_cfg         (1100): 0x08019031  ch_flag_cfg         (1104): 0x007E
ch_flwctrl_cfg      (1108): 0x0000      ch_intr_enable      (110C): 0x09FF
ch_cmd_stat         (110E): 0x0050
WIC Serial DMA Registers:
Rx ring_start_ptr   (2000): 0x0EA9B080  Rx ring_mask_index  (2004): 0x00F80000
internal_desc_stat  (2008): 0x0400060C  internal_buff_addr  (200C): 0x0EAA9740
internal_context    (2010): 0x00000013  internal_fifo_data  (2014): 0x0EAA9740
Tx ring_start_ptr   (2200): 0x0EA9D080  Tx ring_mask_index  (2204): 0x03F80018
internal_desc_stat  (2208): 0x00000000  internal_buff_addr  (220C): 0x0DDA4E6C
internal_context    (2210): 0x00000301  internal_fifo_data  (2214): 0xDB60442B
WIC Serial Interface Registers:
intf_ctrl           (3000): 0x1000      modem_ctrl          (3002): 0x0118
flow_ctrl           (3004): 0xB070      brg dvdr            (3006): 0x0000
WIC TDM/FREQ Counter Registers:
tdm_control         (3100): 0x0000      tdm_a_8k_divider    (3102): 0x0000
tdm_b_8k_divider    (3104): 0x0000
freq_count_port_sel (310A): 8           freq_count          (310C):  1030793
TDM Control Registers:
  tmdsw_ctl                              (addr 0x104B0040): 0x28070A4A
  vmcr[0]                                (addr 0x104B0060): 0x28070892
  vmcr[1]                                (addr 0x104B0064): 0x280708DA
  vmcr[2]                                (addr 0x104B0068): 0x28070922
  vmcr[3]                                (addr 0x104B006C): 0x2807096A
  ntr_cr0                                (addr 0x104B0078): 0x280709B2
  ntr_cr1                                (addr 0x104B0080): 0x280709FA
  tpllr_cr                               (addr 0x104B0088): 0x25110000
  sm_tdm_cr                              (addr 0x104B0070): 0x2807088A
  pvdm_tdm_cr                            (addr 0x104B0074): 0x280708D2
968 input aborts on receiving flag sequence
0 throttles, 0 enables
30 overruns
0 transmitter underruns
322 transmitter CTS losts
919 rxintr, 982 txintr, 0 rxerr, 0 txerr
0 tx_abort 0 tx_reset
tx_limited = 1(2) tx_count = 0
Receive Ring
rxr head (0)(0x0EA9B080), rxr tail (0)(0x0EA9B080)
  rmd(EA9B080): stats_len 8400060C buff_addr EAA9740
  rmd(EA9B088): stats_len 8400060C buff_addr EAB5CE0
  rmd(EA9B090): stats_len 8400060C buff_addr EAAA400
  rmd(EA9B098): stats_len 8400060C buff_addr EAB6340
  rmd(EA9B0A0): stats_len 8400060C buff_addr EAAAA60
  rmd(EA9B0A8): stats_len 8400060C buff_addr EAAB0C0
  rmd(EA9B0B0): stats_len 8400060C buff_addr EAAB720
  rmd(EA9B0B8): stats_len 8400060C buff_addr EAABD80
  rmd(EA9B0C0): stats_len 8400060C buff_addr EAAC3E0
  rmd(EA9B0C8): stats_len 8400060C buff_addr EAACA40
  rmd(EA9B0D0): stats_len 8400060C buff_addr EAAD0A0
  rmd(EA9B0D8): stats_len 8400060C buff_addr EAAD700
  rmd(EA9B0E0): stats_len 8400060C buff_addr EAADD60
  rmd(EA9B0E8): stats_len 8400060C buff_addr EAAE3C0
  rmd(EA9B0F0): stats_len 8400060C buff_addr EAAEA20
  rmd(EA9B0F8): stats_len 8400060C buff_addr EAAF080
  rmd(EA9B100): stats_len 8400060C buff_addr EAAF6E0
  rmd(EA9B108): stats_len 8400060C buff_addr EAAFD40
  rmd(EA9B110): stats_len 8400060C buff_addr EAB03A0
  rmd(EA9B118): stats_len 8400060C buff_addr EAB0A00
  rmd(EA9B120): stats_len 8400060C buff_addr EAB1060
  rmd(EA9B128): stats_len 8400060C buff_addr EAB16C0
  rmd(EA9B130): stats_len 8400060C buff_addr EAB1D20
  rmd(EA9B138): stats_len 8400060C buff_addr EAB2380
  rmd(EA9B140): stats_len 8400060C buff_addr EAB29E0
  rmd(EA9B148): stats_len 8400060C buff_addr EAB3040
  rmd(EA9B150): stats_len 8400060C buff_addr EAB36A0
  rmd(EA9B158): stats_len 8400060C buff_addr EAB3D00
  rmd(EA9B160): stats_len 8400060C buff_addr EAB4360
  rmd(EA9B168): stats_len 8400060C buff_addr EAB49C0
  rmd(EA9B170): stats_len 8400060C buff_addr EAB5020
  rmd(EA9B178): stats_len 8400060C buff_addr EAB5680
Transmit Ring
txr head (1)(0x0EA9D088), txr tail (1)(0x0EA9D088)
  tmd(EA9D080): sts_len 01C00000 buf_addr DDA5BD4
  tmd(EA9D088): sts_len 00000000 buf_addr 0
  tmd(EA9D090): sts_len 00000000 buf_addr 0
  tmd(EA9D098): sts_len 00000000 buf_addr 0
  tmd(EA9D0A0): sts_len 00000000 buf_addr 0
  tmd(EA9D0A8): sts_len 00000000 buf_addr 0
  tmd(EA9D0B0): sts_len 00000000 buf_addr 0
  tmd(EA9D0B8): sts_len 00000000 buf_addr 0
  tmd(EA9D0C0): sts_len 00000000 buf_addr 0
  tmd(EA9D0C8): sts_len 00000000 buf_addr 0
  tmd(EA9D0D0): sts_len 00000000 buf_addr 0
  tmd(EA9D0D8): sts_len 00000000 buf_addr 0
  tmd(EA9D0E0): sts_len 00000000 buf_addr 0
  tmd(EA9D0E8): sts_len 00000000 buf_addr 0
  tmd(EA9D0F0): sts_len 00000000 buf_addr 0
  tmd(EA9D0F8): sts_len 00000000 buf_addr 0
  tmd(EA9D100): sts_len 00000000 buf_addr 0
  tmd(EA9D108): sts_len 00000000 buf_addr 0
  tmd(EA9D110): sts_len 00000000 buf_addr 0
  tmd(EA9D118): sts_len 00000000 buf_addr 0
  tmd(EA9D120): sts_len 00000000 buf_addr 0
  tmd(EA9D128): sts_len 00000000 buf_addr 0
  tmd(EA9D130): sts_len 00000000 buf_addr 0
  tmd(EA9D138): sts_len 00000000 buf_addr 0
  tmd(EA9D140): sts_len 00000000 buf_addr 0
  tmd(EA9D148): sts_len 00000000 buf_addr 0
  tmd(EA9D150): sts_len 00000000 buf_addr 0
  tmd(EA9D158): sts_len 00000000 buf_addr 0
  tmd(EA9D160): sts_len 00000000 buf_addr 0
  tmd(EA9D168): sts_len 00000000 buf_addr 0
  tmd(EA9D170): sts_len 00000000 buf_addr 0
  tmd(EA9D178): sts_len 00000000 buf_addr 0
  tmd(EA9D180): sts_len 00000000 buf_addr 0
  tmd(EA9D188): sts_len 00000000 buf_addr 0
  tmd(EA9D190): sts_len 00000000 buf_addr 0
  tmd(EA9D198): sts_len 00000000 buf_addr 0
  tmd(EA9D1A0): sts_len 00000000 buf_addr 0
  tmd(EA9D1A8): sts_len 00000000 buf_addr 0
  tmd(EA9D1B0): sts_len 00000000 buf_addr 0
  tmd(EA9D1B8): sts_len 00000000 buf_addr 0
  tmd(EA9D1C0): sts_len 00000000 buf_addr 0
  tmd(EA9D1C8): sts_len 00000000 buf_addr 0
  tmd(EA9D1D0): sts_len 00000000 buf_addr 0
  tmd(EA9D1D8): sts_len 00000000 buf_addr 0
  tmd(EA9D1E0): sts_len 00000000 buf_addr 0
  tmd(EA9D1E8): sts_len 00000000 buf_addr 0
  tmd(EA9D1F0): sts_len 00000000 buf_addr 0
  tmd(EA9D1F8): sts_len 00000000 buf_addr 0
  tmd(EA9D200): sts_len 00000000 buf_addr 0
  tmd(EA9D208): sts_len 00000000 buf_addr 0
  tmd(EA9D210): sts_len 00000000 buf_addr 0
  tmd(EA9D218): sts_len 00000000 buf_addr 0
  tmd(EA9D220): sts_len 00000000 buf_addr 0
  tmd(EA9D228): sts_len 00000000 buf_addr 0
  tmd(EA9D230): sts_len 00000000 buf_addr 0
  tmd(EA9D238): sts_len 00000000 buf_addr 0
  tmd(EA9D240): sts_len 00000000 buf_addr 0
  tmd(EA9D248): sts_len 00000000 buf_addr 0
  tmd(EA9D250): sts_len 00000000 buf_addr 0
  tmd(EA9D258): sts_len 00000000 buf_addr 0
  tmd(EA9D260): sts_len 00000000 buf_addr 0
  tmd(EA9D268): sts_len 00000000 buf_addr 0
  tmd(EA9D270): sts_len 00000000 buf_addr 0
  tmd(EA9D278): sts_len 00000000 buf_addr 0
  tmd(EA9D280): sts_len 00000000 buf_addr 0
  tmd(EA9D288): sts_len 00000000 buf_addr 0
  tmd(EA9D290): sts_len 00000000 buf_addr 0
  tmd(EA9D298): sts_len 00000000 buf_addr 0
  tmd(EA9D2A0): sts_len 00000000 buf_addr 0
  tmd(EA9D2A8): sts_len 00000000 buf_addr 0
  tmd(EA9D2B0): sts_len 00000000 buf_addr 0
  tmd(EA9D2B8): sts_len 00000000 buf_addr 0
  tmd(EA9D2C0): sts_len 00000000 buf_addr 0
  tmd(EA9D2C8): sts_len 00000000 buf_addr 0
  tmd(EA9D2D0): sts_len 00000000 buf_addr 0
  tmd(EA9D2D8): sts_len 00000000 buf_addr 0
  tmd(EA9D2E0): sts_len 00000000 buf_addr 0
  tmd(EA9D2E8): sts_len 00000000 buf_addr 0
  tmd(EA9D2F0): sts_len 00000000 buf_addr 0
  tmd(EA9D2F8): sts_len 00000000 buf_addr 0
  tmd(EA9D300): sts_len 00000000 buf_addr 0
  tmd(EA9D308): sts_len 00000000 buf_addr 0
  tmd(EA9D310): sts_len 00000000 buf_addr 0
  tmd(EA9D318): sts_len 00000000 buf_addr 0
  tmd(EA9D320): sts_len 00000000 buf_addr 0
  tmd(EA9D328): sts_len 00000000 buf_addr 0
  tmd(EA9D330): sts_len 00000000 buf_addr 0
  tmd(EA9D338): sts_len 00000000 buf_addr 0
  tmd(EA9D340): sts_len 00000000 buf_addr 0
  tmd(EA9D348): sts_len 00000000 buf_addr 0
  tmd(EA9D350): sts_len 00000000 buf_addr 0
  tmd(EA9D358): sts_len 00000000 buf_addr 0
  tmd(EA9D360): sts_len 00000000 buf_addr 0
  tmd(EA9D368): sts_len 00000000 buf_addr 0
  tmd(EA9D370): sts_len 00000000 buf_addr 0
  tmd(EA9D378): sts_len 00000000 buf_addr 0
  tmd(EA9D380): sts_len 00000000 buf_addr 0
  tmd(EA9D388): sts_len 00000000 buf_addr 0
  tmd(EA9D390): sts_len 00000000 buf_addr 0
  tmd(EA9D398): sts_len 00000000 buf_addr 0
  tmd(EA9D3A0): sts_len 00000000 buf_addr 0
  tmd(EA9D3A8): sts_len 00000000 buf_addr 0
  tmd(EA9D3B0): sts_len 00000000 buf_addr 0
  tmd(EA9D3B8): sts_len 00000000 buf_addr 0
  tmd(EA9D3C0): sts_len 00000000 buf_addr 0
  tmd(EA9D3C8): sts_len 00000000 buf_addr 0
  tmd(EA9D3D0): sts_len 00000000 buf_addr 0
  tmd(EA9D3D8): sts_len 00000000 buf_addr 0
  tmd(EA9D3E0): sts_len 00000000 buf_addr 0
  tmd(EA9D3E8): sts_len 00000000 buf_addr 0
tmd(EA9D3F0): sts_len 00000000 buf_addr 0
  tmd(EA9D3F8): sts_len 00000000 buf_addr 0
  tmd(EA9D400): sts_len 00000000 buf_addr 0
  tmd(EA9D408): sts_len 00000000 buf_addr 0
  tmd(EA9D410): sts_len 00000000 buf_addr 0
  tmd(EA9D418): sts_len 00000000 buf_addr 0
  tmd(EA9D420): sts_len 00000000 buf_addr 0
  tmd(EA9D428): sts_len 00000000 buf_addr 0
  tmd(EA9D430): sts_len 00000000 buf_addr 0
  tmd(EA9D438): sts_len 00000000 buf_addr 0
  tmd(EA9D440): sts_len 00000000 buf_addr 0
  tmd(EA9D448): sts_len 00000000 buf_addr 0
  tmd(EA9D450): sts_len 00000000 buf_addr 0
  tmd(EA9D458): sts_len 00000000 buf_addr 0
  tmd(EA9D460): sts_len 00000000 buf_addr 0
  tmd(EA9D468): sts_len 00000000 buf_addr 0
  tmd(EA9D470): sts_len 00000000 buf_addr 0
  tmd(EA9D478): sts_len 00000000 buf_addr 0
buffer size 1524
David,
Did they tell you that they had you configured for frame relay? If you connect their router to the smartjack, does the circuit work? If so, you can try to change your configuration like so:
encaps frame-relay
inter s0/0/0.500 point-to-point
See if that helps your issue...
HTH,
John
j.blakley wrote:
David,
encaps frame-relay
HTH,
John
They did not mention anything, when i ask for help they just give me the ip configuration that i already have.
i tried the configuration you gave me and it did not work.
thanks for the reply.
David,
If that didn't work, the next step is to get in touch with the provider as Paolo suggested. I find it suspicious that they have their provider router configured for FR and they're telling you to configure for hdlc. The initial configuration that you have would work if they're providing the correct information. The provider will have to provide you the correct encapsulation in order for you to keep a link up. Also, when you call you may want to ask them why their router that they've given you is configured for frame relay....FR encapsulation and HDLC encapsulation are 2 different things and will not work between the two.
30 overruns
HTH,
John
j.blakley wrote:
David,
30 overruns
HTH,
John
I will try that again, thanks for your help.
John,
i apologize i did not notice this before. on the adtran device i found this.
interface t1 1/1
  tdm-group 1 timeslots 1-24 speed 64
  no shutdown
interface fr 1 point-to-point
  frame-relay lmi-type ansi
  max-reserved-bandwidth 100
  no shutdown
  cross-connect 1 t1 1/1 1 frame-relay 1
i dont know it it will be of any help.
thanks.
Can you post your running-config from the router?
Does the circuit work if you are using just the provider's router?
yes, it works if i use the ethernet port.
i erased some specifics on the following. (i hope i didnt miss anything)
we have a dsl line connected to the router, that will be the default gateway but the t1 will only be used by a set of devices.
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$YAn7$PLC3uW2H4lQ7p/n8mxrZk1
enable password
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.2 192.168.1.50
ip dhcp pool pool1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server
domain-name b
ip domain name b
crypto pki trustpoint TP-self-signed-1892
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1892
revocation-check none
rsakeypair TP-self-signed-1892
crypto pki certificate chain TP-self-signed-1892
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
        quit
license udi pid
username .
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description inside network
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description Outside
ip address 2.2.2.2 255.255.255.0
ip nat outside
duplex auto
speed auto
description T1
no ip address
encapsulation frame-relay
interface Serial0/0/0.500 point-to-point
ip default-gateway 2.2.2.2
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip nat inside source static tcp 192.168.1.20 80 interface GigabitEthernet0/1 80
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route 192.168.2.0 255.255.255.0 192.168.1.2
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
password
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
password
login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
password
login local
scheduler allocate 20000 1000
end
If it works while connected to the ethernet port, the circuit is configured for FR. It's best that you contact them for the settings that you need. If you have the interface up while configured for FR (as you are now), does the interface go up/up?
