Imporoper NATting issue
kpillai
I have a cisco 2600 router doing nat. Dynamic and static nat's are configured on this router. The nat is working properly but the wierd problem I have is, the dynamic NAT ip address is getting natted to a different IP address (static ) instead of the IP address (overlaod) assigned. If I reboot the router, it is getting natted to the correct IP address and after a while it is natting to th static IP.
I have attached the configuration and the output of the NAT translation for you gurus.
version 12.0
service password-encryption
logging buffered 4096 debugging
process-max-time 200
ip subnet-zero
interface Ethernet0/0
ip address 192.168.200.50 255.255.255.0
no ip directed-broadcast
ip nat outside
interface Serial0/0
no ip address
encapsulation frame-relay IETF
service-module t1 timeslots 1-4
interface Serial0/0.2 point-to-point
description ATM to HQ
ip address 172.31.0.21 255.255.255.252
ip access-group 1 in
ip accounting output-packets
ip nat inside
frame-relay interface-dlci 40
router eigrp 2
redistribute static
network 172.16.0.0
network 172.31.0.0
network 192.168.21.0
network 192.168.40.0
network 192.168.170.0
network 192.168.200.0
no auto-summary
ip nat pool corpay 192.168.200.59 192.168.200.59 netmask 255.255.255.0
ip nat inside source list 102 pool corpay overload
ip nat inside source static 172.16.2.36 192.168.200.56
ip nat inside source static 172.16.0.52 192.168.200.53
ip nat inside source static 172.16.0.51 192.168.200.52
ip nat inside source static 172.16.0.75 192.168.200.51
ip nat inside source static 172.16.0.100 192.168.200.54
ip nat inside source static 172.16.0.2 192.168.200.55
ip classless
ip route 192.168.21.0 255.255.255.0 192.168.200.6
ip route 192.168.40.0 255.255.255.0 192.168.200.6
ip route 192.168.170.0 255.255.255.0 192.168.200.6
access-list 1 permit any
access-list 102 permit ip 172.16.0.0 0.15.255.255 any
line con 0
transport input none
speed 115200
line aux 0
modem Dialin
line vty 0 4
password 7 <removed>
login
end
As soon as I reboot the router and ping from my pc to 192.168.21.10, I get a reply and below is the NAT translation
Livonia_MI#sh ip nat trans
Pro Inside global Inside local Outside local Outside global
--- 192.168.200.51 172.16.0.75 --- ---
--- 192.168.200.52 172.16.0.51 --- ---
--- 192.168.200.53 172.16.0.52 --- ---
--- 192.168.200.54 172.16.0.100 --- ---
--- 192.168.200.55 172.16.0.2 --- ---
--- 192.168.200.56 172.16.2.36 --- ---
icmp 192.168.200.59:512 172.16.0.230:512 192.168.21.10:512 192.168.21.10:512
tcp 192.168.200.59:1812 172.16.0.230:1812 192.168.21.10:23 192.168.21.10:23
After 2 hours, if I ping to 192.168.21.10 from my pc, I get a reply but the source address is translated to 192.168.200.53 which is supposed to be staticNAT.
icmp 192.168.200.53:512 172.16.0.230:512 192.168.21.10:512 192.168.21.10:512
udp 192.168.200.53:137 172.16.0.32:137 192.168.21.1:137 192.168.21.1:137
If I restart the router, the NATting working properly and after some time it starts tranlsating to the wrong IP address.
Gurus, please look at the configration and let me knof if I am doing anything wrong.
Kumar
thisisshanky
Level 11
Level 11
What IOS version are you running on the box ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The version is 12.0(5) T1
