Import RSA Keys for SSH
hclisschennai
I have the router configured for SSH and it is working good. I know how to configure SSH in router using crypto command. The new requirement araised now.
My organisation has created a pair of key - PULIC KEY & PRIVATE KEY common to the company using some mechanism. The idea is the PUBLIC KEY will be installed in the devices like Unix, Linux Servers. so the staff who is owing the PRIVATE KEY is only be allowed to access the device.
I am trying to add / install / import the PUBLIC KEY into the Router in similar fashion. But i am not getting clue how to go ahead. Please guide me how to import the PUBLIC KEY into the Router, so that who ever is having the PRIVATE KEY is only allowed to login to the device.
Can anybody help me how to achieve this
lejoe.thomas
Level 3
Level 3
There is an option to import keys in PEM-Formatted Files and PKCS12 Files
Hope the documentation helps
http://www.cisco.com/en/US/docs/ios/security/configuration/guide/sec_deploy_RSA_piki_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1055433
Lejoe
Hi Lejoe.
Thankyou for your response. I appreciate.
I will follow this and revert if any more clarification is required
Hi All,
Recently I came across one customer and my customer wanted me to show the steps. I did it in my lab environment, you can go through the below.  It might be useful.
  1. Configure RSA key as exportable.
C2911-2(config)#crypto key generate rsa label test exportable modulus 2046
The name for the keys will be: test
% The key modulus size is 2046 bits
% Generating 2046 bit RSA keys, keys will be exportable...
[OK] (elapsed time was 5 seconds)
  1. Export the key and save it offline
C2911-2(config)#crypto key export rsa test pem terminal  3des cisco123456
% Key name: test
   Usage: General Purpose Key
   Key data:
-----BEGIN PUBLIC KEY-----
MIIBITANBgkqhkiG9w0BAQEFAAOCAQ4AMIIBCQKCAQAvnyD4fBiBA2/1UoPzoJmQ
IWqVKgTvv9Uj4ITo5s9h6//L0Zv7n9sKaXduMKyjVT0ge/ZjInskqmuYTZT3V88S
xELlmF0Sq3+SvW1n9OV84vhh6FZXwKnAvIxuJdnjrhg9If9FPjcLScOyKUYsNn7d
7Aev2yv/GkAAN1hxqp515PawUvSyxktOROxjS0fU/bBOAmC33XwFZv54GczegkBn
T+BoQCJO+IqA4HHwNQRayiRGfX46jtnNlEvxKUkVbImDc0l6Tkh6aXoPQ2cAznbw
OQ+esj5bXsSI/tNVPZufNZtzpcCS3bUwRF747zOXSvh825KhrOQ0P+0nzw9fs4mp
AgMBAAE=
-----END PUBLIC KEY-----
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,47D4C87916A56404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-----END RSA PRIVATE KEY-----
  1. To import the key from offline to the box, use the below command,
C2911-2(config)#crypto key import rsa test1 terminal cisco123456
% Enter PEM-formatted public General Purpose key or certificate.
% End with a blank line or "quit" on a line by itself.
AgMBAAE=
quit
% Enter PEM-formatted encrypted private General Purpose key.
% End with "quit" on a line by itself.
quit
% Key pair import succeeded.
Gowthamii Rao
