in MobaXterm when I press enter it is jumping two lines
MaheshB0ddu
I have typed below command, normally it has to let me enter yes or no but in mobaxterm when i press enter it is jumping to next line R1#, skipping Reset ALL OSPF processes? [no]:
anyone faced this? pls help.
R1#clear ip ospf process
R1#
8 Replies 8
vishalbhandari
@MaheshB0ddu This issue in MobaXterm is likely due to how it handles keyboard input, particularly with interactive prompts. Try enabling "Local echo" in the terminal settings or switching to a different terminal emulator like PuTTY or SecureCRT to see if the issue persists. You can also try adding force to the command (clear ip ospf process force) to bypass the confirmation prompt.
Thanks for the suggestion but unfortunately it didnt work. enabled local echo but no change
Nortant
Try to change this:
I faced the same issue as yours. It works for me
Hi Nortant,
thanks but it didn't worked for me, Im not getting why,
please go thru my settings and guide me
Have you restarted another new session after you set it up?
And I also checked this option.
Forgive me, I just got it successful only once. The issue came again for me...
Hi Nortant,
 you atleast got once, Thank you for your time
I will let you know if I get any solution for this.
why im looking for Mobaxterm is the terminal is so detailed with colours (differentiation) and we can easily observe things in cli, i liked that feature.
I agree with you, the same reason.
I use it for my eve-ng, when I double click the node, I can open MobaXterm.
My issue is that only double-clicking the node in the web GUI and opening MobaXterm will have this issue; if I make a new session in MobaXterm, there is no issue. I'm sure it's not the router issue.
etiennebuxin
have you the same issue with another terminal emulator like Putty?
No -> issue is probably with mobaxterm config
Yes -> issue is probably on the router
