12-19-2018 02:56 PM - edited 03-05-2019 11:07 AM
I'm sure this has been asked before but I couldn't figure out the keywords needed for the search.
Currently I have a default route set like
ip route 0.0.0.0 0.0.0.0 12.161.x.x #<g0/0/0>
this works fine, but I want to say that if the router receives any packets from 172.x.x.x / 20 send instead to 10.1.1.1 <g0/1/0>
I think this is an ACL waiting to happen but I'm not sure exactly how to configure it.
I don't have any advanced features on the router, so I can't enable vrf or anything like that. It's a 2901.
Thanks in advance for any help.
Solved! Go to Solution.
12-20-2018 01:40 AM - edited 12-20-2018 01:41 AM
Hello
As stated sounds like PBR would be applicable.
Example:
ip sla 1
icmp-echo 10.1.1.1 <-- tracked destination
ip sla schedule 1 life forever start-time now
track 5 sla 1 reachability
access-list 10 permit 172.x.x.x 0.0.15.255
route-map PBR permit 10
match ip address 10
set ip next-hop verify-availability 10.1.1.1 1 track 5
int x/x
Description 172.x.x.x incoming interface
ip polcy route-map PBR
exit
12-19-2018 03:11 PM
What you are looking for is called, policy based routing,
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/10116-36.html
and you are correct part of its configuration is done, using ACLs
Hello
Example:
ip sla 1
match ip address 10
int x/x
exit
12-20-2018 08:36 AM
Thanks guys, I will try this and report back.
12-26-2018 06:53 PM
What if the route is coming in through a BGP connection so there is no interface on the router that matches the subnet that I want to apply a policy route to. Does that work? This is impossible to test in packet tracer and hard to get close to my configuration in GNS3.
