How to replace fan incisco 2811 router?
TangoAlfa
How to replace fan incisco 2811 router in live or down condition?
Giuseppe Larosa
Hello Tanmay,
being not a modular model, the ufficial answer should be that you need to change the whole router
sorry for the bad news
Hope to help
Giuseppe
Hi Giuseppe
                 There is no module right but you can change that open the case.I have done by myself.
Thanks For your previous suggestion...
Tanmay
Hi , Can you confirm is it hot swappable or not?
