Increase IP nat translation total on Cisco ISR 4331
adityasinghhj13
at present i am having Cisco ISR 4331 running IOS 16.6.4.
I want to increase the nat translations total from 131400 to 200000 , in order to do so should i increase the value using ip nat translation max-entries 200000 or ip nat translation max-entries all-hosts 200000.
Can someone help its urgent now...
7 Replies 7
 "The ip nat translation max-entries all-host command can be used in scenarios where the Cisco ASR
1000 Series Router acting as ISG, performs NAT on all or most of the subscriber traffic. This helps the
operator to prevent a single host from occupying the entire translation table, while allowing a reasonable
upper limit to each host."
In your case,  you should change the max entry with the command ip nat translation max-entries 200000
Hello Flavio,
thankyou for your information i did the same and ran ip nat translation max-entries 200000 now how to check if the NAT Translation limit has been increased to 200000 , i tried all the show command for show ip nat translational but non of them show me the limit to which it has extended.
and to add the router was in HA active/standby setup , so i ran on both the routers once i saw translation being done on both routers, please let me know if my approach on running the command on both the routers was correct on not.
Thanks in advance
Hello @adityasinghhj13
   Sorry but actually the information I gave you was not right. Both command :
Will change the nat translation capacity for each host connected.  As per my searches, you can not change the NAT capacity of the router. The NAT capacity will be a sum up of CPU, Memory and Throughput.
What you can change is the licensing type in order to increase the Router capacity. The NAT limit will be related to Throughput capacity.
able 4.             Specifications of Cisco 4000 Family Integrated Services Routers
Technical Specifications
Cisco 4461
Cisco 4451
Cisco 4431
Cisco 4351
Cisco 4331
Cisco 4321
Cisco 4221
Aggregate Throughput (Default)
1.5Gbps
1 Gbps
500 Mbps
200 Mbps
100 Mbps
50 Mbps
35Mbps
Aggregate Throughput (Performance License)
3Gbps
2 Gbps
1 Gbps
400 Mbps
300 Mbps
100 Mbps
75 Mbps
Aggregate CEF Only[5] Throughput (Boost License)
Over 7Gbps
Over 4Gbps
Over 4Gbps
Over 2Gbps
Over 2Gbps
1.5Gbps
I will try both command in csr1000v.
Update you soon.
Thankyou in advance
the effect of all-host max with config of max-entries
NOW we have CSR1000v with max entries 2 and max all-host 1
what this do
this will allow R1 to have one entry in NAT table
and allow R2 to have one entry in NAT table
this total = 2 which is what we config in max-entries
so here we must careful if we have
if we have host 10 and set max all-host to 10 and later we set max-entries 50 then 5 host cannot use NAT since the UPPER limit ot total all NAT is reach.
here if you want to specify NAT for each host use max all-host and adjust the max-entries
if you want to specify ONLY UPPPER limit to total all NAT then only config max=entries
Screenshot (748).pngScreenshot (749).pngScreenshot (750).pngScreenshot (751).pngScreenshot (752).png
Hello
Why do you need to increase the nat table size, doing this can impact the whole rtr, I assume you are overloading - How may users do you have internally?
Kind Regards
Paul
