Information on CISCO WS-C3750G-12S-E
perpaal
I have some CISCO WS-C3750G-12S-E with IOS version 12.2(58)SE
Now I have been offered some used units with IOS version 12.2(55)SE for a good price.
Is there any hardware differences on this model (possible memory configurations etc), or will I easily be able to upgrade?
From factory default all those modesl have same hardware configuration untill you upgrade those like memory or flash.
You can absolutely go ahead with the upgradation part.
Please click on the correct answer if this answered your question.
Naidu.
Latchum Naidu
What does this mean?
Do you want upgrade from 12.2(55)SE to 12.2(58)SE if yes then you can without any issues.
Naidu.
Yes, that was basicly the question.
Also, are there more than one hardware configuration on this spesific model (memory, flash, CPU etc)?
Naidu.
