Inistalling NM-1T3/E3 card in 3845 router
mvsheik123
Level 7
Level 7
Hi All,
Do I need to shut down the 3845 router in order to install additional (one existing already) NM-1T3/E3 Module? Or the Module can be inserted while the router is up and 'Sh ver' gives the card information for further configuring (card type etc).
TIA
MS
Leo Laohoo
The module does NOT support Online Insertion and Removal (OIR) so you need to power down the router and insert the module.  Just make sure you have the right IOS and Feature set.
Leo Laohoo
Thank you. The router got 12.4 (3d) IOS. Per docs it is good enough.
Good enough indeed and thank you for the rating.
