Injecting eigrp route to ospf
feroz syed
Level 3
Level 3
please check this diagram, ospf running in frame relay cloud (hub and spoke)  everything work fine, but after adding Router 4 (Eigrp) the other routers can't reach to router4 but it can ping Router1 eigrp interface(75.75.75.1).
Router1 config
Building configuration...
Current configuration : 1785 bytes
upgrade fpd auto
version 12.4
hostname R1
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
interface Loopback1
ip address 192.168.100.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.12.123.1 255.255.255.0
encapsulation frame-relay IETF
ip ospf authentication
ip ospf authentication-key ccna
serial restart-delay 0
frame-relay map ip 172.12.123.3 103
frame-relay map ip 172.12.123.2 102
no frame-relay inverse-arp
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
ip address 75.75.75.1 255.255.255.0
duplex full
router eigrp 100
network 75.75.75.0 0.0.0.255
no auto-summary
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
redistribute eigrp 100 subnets
network 172.12.123.0 0.0.0.255 area 10
network 192.168.100.0 0.0.0.255 area 0
neighbor 172.12.123.2
neighbor 172.12.123.3
ip forward-protocol nd
no ip http server
no ip http secure-server
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
Router 1 ip route:-
Gateway of last resort is not set
     172.12.0.0/24 is subnetted, 1 subnets
C       172.12.123.0 is directly connected, Serial1/0
     10.0.0.0/24 is subnetted, 1 subnets
O IA    10.10.10.0 [110/74] via 172.12.123.2, 18:57:01, Serial1/0
     192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C       192.168.100.0/24 is directly connected, Loopback1
O IA    192.168.100.241/32 [110/65] via 172.12.123.2, 18:56:57, Serial1/0
     75.0.0.0/24 is subnetted, 1 subnets
C       75.75.75.0 is directly connected, FastEthernet2/0
Router 4 config :-
Current configuration : 1255 bytes
upgrade fpd auto
version 12.4
hostname R4
boot-start-marker
boot-end-marker
enable secret 5 $1$VDzc$i.iE1GdCmTMg3oG0BeqRK0
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
archive
log config
  hidekeys
ip tcp synwait-time 5
no ip address
shutdown
duplex half
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
ip address 75.75.75.75 255.255.255.0
duplex full
speed auto
interface GigabitEthernet2/0
ip address dhcp
negotiation auto
router eigrp 100
no auto-summary
you have to redistribute both processes into the other because what you had done is tell OSPF about EIGRP routes but EIGRP has to know about OSPF routes too.
Regards.
Alain
cadet alain
on R1:
router eigrp 100
redistribute ospf 1 metric 1 1 1 1 1
Alain
Thanks for your reply.
why this command not work  R1 redistribute eigrp 100 subnet
Regards.
Alain
Thanks for your help
