input error
bruno.trombim
Community Member
Hi Guys,
i am working in a company that is facing the problem of mpls slowness networking , i was checking some command and faced the trouble input error in the FastEthernet 0/1, this fastEthernet is configured with 8 sub-interface linked in a switch, one of those sub-interface is our mpls set that are connected in our another site, users are complaining slowness to access this site, so my question is this input error may be the problem cause for this issue, what i could check for isolating it and get the solution.
FastEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 04fe.7f59.60c1 (bia 04fe.7f59.60c1)
Description: Redelocal
Internet address is 192.168.22.17/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 40/255, rxload 40/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 18:29:09
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 6753
Queueing strategy: Class-based queueing
Output queue: 0/1000/0 (size/max total/drops)
5 minute input rate 15766000 bits/sec, 2018 packets/sec
5 minute output rate 15737000 bits/sec, 2002 packets/sec
131588600 packets input, 1219724295 bytes
Received 789755 broadcasts, 0 runts, 0 giants, 1 throttles
3594 input errors, 0 CRC, 0 frame, 0 overrun, 3594 ignored
0 watchdog
130715748 packets output, 968445176 bytes, 0 underruns
2216 unknown protocol drops
0 lost carrier, 0 no carrier
Best Regards,
Bruno Trombim
Pawan Raut
Level 10
Level 10
from your output
input errors are because of ignored packet. Ignored packets are on the router due to traffic overload or faulty interface.
Kindly follow below KB for more information and rate my post.
5 Replies 5
Pawan Raut
Level 10
Level 10
from your output
bruno.trombim
Community Member
so it means my interface may be overloaded with a lot of subinterface and traffic to be handled, it may be solved if a separate some sub-interface in another fisical interface?
Att,
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Don't overlook the overall context, i.e. 3,594 ignored over 131,588,600 packets input, a miniscule percentage.
You may find you might need to do much more analysis to determine the cause.
which tools or first aid should i  use to detect this issue?
best regards,
Bruno
3500+ ignore count when viewed with 131Million pkts is insignificant. Ignores ARE NOT causing the slow performance problem you are experiencing. Troubleshooting slowness is very complex, especially in a supportforum.
Are you responsible for the network infrastructure OR for the server infrastructure also?
Please describe the slow performance problem in detail. Include where the end-points are located. Describe the user experience when they say slow.
