Input errors on Fastethernet increasing
I'm using a Cisco 1812 to route traffic from a small location with 10 users.. Users are complaning about packet loss, and programs with live database connection is freezing..
On the router i've checked one of the Fastethernet interfaces, and I can see that the input errors are increasing constantly. Anyone know what the cause might be? The only thing I can think of is a damaged ethernet cable..
  16955 packets input, 11809421 bytes
     Received 479 broadcasts, 33 runts, 0 giants, 0 throttles
    356 input errors, 356 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     13266 packets output, 3010818 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Best Regards,
Steffen.
Steffen
You are seeing rising CRC errors
This could mean that their is a duplex mismatch between the 1812 and whatever the device
is at the other end of the cable.
What is the config for this interface on the 1812 and what
does it connect to .
Alex
Regards, Alex. Please rate useful posts.
5 Replies 5
avi
This indicate that there is some physical layer problem,
first change the cable & see if the problem resolve or not.
If not there could be the some issue with the service provider.
The last thing to suspect is the router hardware or the physical port.
Okay - thank you I'll try to change the Ethernet Cable and see if it helps..
Steffen
Alex
Hi Alex
It was duplex mismatch.. I've changed it now, and now i do not have increasing CRC errors anymore..
By the way, what is CRC standing for? What does it mean?
Best Regards
CRC = Cyclic Redundancy Check
This is a part of the layer 2 frame which is used to validate the data within the frame
If the CRC is invalid the frame is dropped as an errror
http://en.wikipedia.org/wiki/CRC-based_framing
Most L2 protocol frames use CRCs
HDLC
SDLC
ISDN-LAPD
X25 - LAPB
ETHERNET (802.1)
Alex
