Input queue size have negative figure
johnlee1301
I have a router work in tunnel. When I show interface tunnel, in the input queue, size have a negative figure. May I know why and how should I solve it. Below is one example.
Tunnel113 is up, line protocol is up
Hardware is Tunnel
Description: SJ to PG
Internet address is 192.168.252.138/24
MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive not set
Tunnel source 66.35.197.194 (FastEthernet0/0), destination 210.19.133.21
Tunnel protocol/transport GRE/IP, key disabled, sequencing disabled
Tunnel TTL 255
Checksumming of packets disabled, fast tunneling enabled
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:50:42
Input queue: -995291044/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute output rate 0 bits/sec, 1 packets/sec
33251 packets input, 6865110 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
39546 packets output, 21799455 bytes, 0 underruns
m.singer
Level 4
Level 4
The problem may be due to router running older version of IOS
