Inquiry about backup power compatibility for C8200-1N-4T
quang-nv
Hi everyone,
Regarding the backup power for the C8200-1N-4T
Whether the PWR-CC1-150WAC can be used as a backup for the built-in power supply on the C8200-1N-4T device, or if it is only intended to support the PoE module?
M02@rt37
Hello @quang-nv
PWR-CC1-150WAC power supply does not support the router’s main (mean platform) power. Its role is limited to providing 54volt Poe power for the switch ports or poe modules.
https://www.cisco.com/c/en/us/products/collateral/routers/catalyst-8200-series-edge-platforms/catalyst-8200-series-edge-platforms-faq.html
Best regards
M02@rt37
Hello @quang-nv
Best regards
