Inserts in GEIP+.
Leeyoungsoo
Dear experts
I have one problem on Cisco 7513 router.
I need to insert GEIP+ on the Cisco 7513
so I insert GEIP+ to slot3 but is not work.
Below log is the "show diag " output.
Slot 3:
Physical slot 3, ~physical slot 0xC, logical slot 3, CBus 0
Microcode Status 0x4
Master Enable, LED, WCS Loaded
Board is analyzed
Pending I/O Status: None
EEPROM format version 1
VIP4-80 RM7000 controller, HW rev 2.04, board revision A0
Serial number: 35413536 Part number: 73-8676-02
Test history: 0x00 RMA number: 00-00-00
Flags: cisco 7000 board; 7500 compatible
EEPROM contents (hex):
0x20: 01 22 02 04 02 1C 5E 20 49 21 E4 02 00 00 00 00
0x30: 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Slot database information:
Flags: 0x4 Insertion time: 0xF4B18684C (00:04:38 ago)
VIP Controller Memory Size: Unknown
--Boot log begin--
IOS (tm) VIP Software (SVIP-DW-M), Version 12.2(6), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 07-Nov-01 16:00 by pwade
Image text-base: 0x600109A8, data-base: 0x603E0000
--Boot log end--
Please let me know the reason.
5 Replies 5
dongdongliu
The GEIP+ is based on the VIP4-80.
when you show diag, output display that Controller Memory Size is *Unkown*. i`m not sure, but I think it is because of IOS version high, maybe 12.1X is suitably for GEIP+. Cisco suggestion is higher than 12.1(3)E.
but, if you have a GBIC, insert it into GEIP+(ignore system error), to our surprise, GBIC will work well on 12.2(6).
please look at this:
http://www.cisco.com/en/US/products/hw/modules/ps2643/products_tech_note09186a0080094b15.shtml
Thanks for your reply.
this router has following ios version
OS (tm) RSP Software (RSP-JSV-M), Version 12.2(6), RELEASE SOFTWARE (fc2)
Compiled Thu 08-Nov-01 02:22 by pwade
Image text-base: 0x600109C8, data-base: 0x619D2000
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: GS Software (RSP-BOOT-M), Version 11.1(8)CA1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ceima1 uptime is 2 years, 4 weeks, 2 days, 5 hours, 44 minutes
System returned to ROM by reload at 15:33:21 gmt Thu Mar 31 2005
System restarted at 15:03:27 gmt Sun Jan 15 2006
System image file is "slot0:rsp-jsv-mz.122-6.bin"
Is that problem?
thanks again
Hi, lee
I`ve met the same problem, then I changed IOS from 122-25 to 122-18, it was solved.
but I`m not sure 122-25 is not compatible with GEIP+. but GBIC is work well with 122-25!
it`s only a suggestion :)
regards
dongdong
Dear dongdong!
As your advise,I changed IOS version from
12.2(6) to 12.1(23)E4 and it was solved.
Thanks for your advise!
Can I ask one more question?
We need to use a ENHANCED ATM DS3 PA and ENHANCED ATM OC3 SMI PA.
So thease port adapters are working in this IOS version?
Thanks again!
dear lee,
please see the below:
PA Bay 0 Information:
ENHANCED ATM OC3 SML PA, 1 ports,FRU: PA-A3-OC3-SML
HW rev 2.00, Board revision A0
Serial number: 2311935 Part number: 73-2528-06
--Boot log begin--
IOS (tm) VIP Software (SVIP-DW-M), Version 12.2(18)S9, RELEASE SOFTWARE (fc1)
we are using ENHANCED ATM OC3 SML PA
it`s working well
SML=Singlemode(LR) Long Reach
SMI=Singlemode(IR) Intermediate Reach
