09-20-2019 03:09 PM - edited 09-20-2019 03:10 PM
Hello, I have to change a Cisco 3845 and install a Cisco ISR 4451. The problem is I have a subinterface with 30 helper-address: When I insert more than 16 directions using helper-address command, I have an error message which says that the router does not support more than 16 helper-address in an interface.
What can I do to solve it, without using another router? The IOS version that I have installed in the router is Fuji 16.8.2. I hope you could give me a piece of advice.
09-20-2019 03:29 PM
Hello
Possible software or licence limitation.
09-20-2019 03:46 PM
Thank you Paul.
I'm sorry, but I haven't found any information about it except that the maxium number of helper-address in an interface can be different depending on the router's model
09-20-2019 04:48 PM
here is the good thread for reference :
https://community.cisco.com/t5/routing/maximum-helper-addresses-per-interface/m-p/3918898
