Installed MPLS VPN. Now what?
santiago.jem
Hi Experts,
After a few weeks of research and frustration, finally installed a working MPLS VPN between 3 sites. Configured 3 CE routers using static route. Default QoS on all location - which means no QoS configured.
My question is, just as the title says - Now what? I wanna know if there are other things that I should actively monitor?
Is MPLS VPN something that is install and practically forget? Or this this something that I should check on everyday?
I know that there's there's saying that - If ain't broke, don't fix it. But I am interested of those things that we can do to improve with what we have.
Hope to hear from you soon.
Thank you.
Jem
lthangli
Its been quite sometime now since this query is posted. Nevertheless, i would like to comment that once the MPLS VPN is operational, there is really nothing to monitor/check on daily basis.
As you rightly said "If ain't broke, don't fix it".
Lal.
Thanks for the reply Lal appreciate it and yes that's exactly what I did.  :D
