%DOT11-4-NO_SSID: No SSID configured. Dot11Radio0 not started
Andrew Duffield
I am trying to configure the ap on a Cisco 887VAMW router but cannot get the Dot11Radio 0 interface to come up, it is stuck on 'reset'
Here is my config:
ap(config)#do sh run
Building configuration...
Current configuration : 2964 bytes
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$E0no$MTZp.nseyRv.1m0Q.Rx4N.
no aaa new-model
dot11 syslog
dot11 ssid XXX
   vlan 1
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mbssid guest-mode dtim-period 1
   wpa-psk ascii 7 113C4A2733400909366931
username admin secret 5 $1$eYC5$ePSDBvwD6VLzMrZxKtBus.
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 broadcast-key vlan 1 change 3600 membership-termination capability-change
 ssid XXX
 antenna gain 0
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface GigabitEthernet0
 description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
 no ip address
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address dhcp client-id GigabitEthernet0
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner exec ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
banner login ^CC
no username cisco
^C
line con 0
 privilege level 15
 login local
 no activation-character
line vty 0 4
 login local
Can anyone assist me on this one?
Thanks alot
If you want an MBSSID setup, you have lacking configuration and incorrect as well:
I'll give you a new sample:
dot11 ssid TEST
  vlan 1
  authentication mode open
  wpa-psk ascii <yourpassword>
  mbssid guest-mode               -One of your mistakes, if you want mbssid, only this line is required
interface dot11radio 0
encryption vlan 1 mode ciphers tkip
  ssid TEST
  mbssid
  no shutdown
interface dot11radio 0.1
  encapsulation dot1q 1 native
  bridge-group 1
interface gigabitethernet0.1
  bridge-group 1
Done!
In your setup, the AP does not know that VLAN1 is the native, its native is the native radio,
that is why we create a sub-interface for it 🙂
Also 'bridge-group 1' should always exist in the native VLAN,
If you want to add more SSID, just do the same (of course skipping the 'native' on the rest) and adding another bridge-group ex; bridge-group 2 vice versa
nkarthikeyan
Level 7
Level 7
Can you check the below mentioned configuration, which is working one... pulled out this from a blog....
Karthik
dot11 ssid TEST
  vlan 1
  ssid TEST
  mbssid
  no shutdown
  bridge-group 1
  bridge-group 1
Done!
