Installing 2 WICs on a 3800
alvarezromeo
I'm installing 2 T1 WICs w/ 2 ports each. I'm going to use 3 of the ports each with it's own T1 card. At the same time I'm going to drop the existing serial DS3 module in favor of these T1 WICs. So if this is the config. of the serial:
interface Serial1/0
ip address 160.x.x.x 255.255.255.252
ip access-group 101 in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
dsu bandwidth 44210
scramble
no cdp enable
how do i go about getting the 3 WICs configured to use this IP and ACL. Do I need to bridge them? If so how?
Here is what's showing on the WICs now.
controller T1 0/0/0
framing esf
linecode b8zs
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
Again I am only using 3 of the interfaces.
paolo bevilacqua
If you control the router on the other side, you can configure multink PPP with the multlink interface.
spremkumar
Level 9
Level 9
hi
As Paul mentioned if these links are terminating on the same router in the remote location then u can make a logical bundle and forward the traffic via the bundle.
But if its terminating on different devices then better to have induvidual links configured to carry the traffic.
regds
