Installing Dual Ethernet Module in 7204
cslack1313
This should be an easy one. I installed a dual Ethernet Module in 7204. I am not able to view those interfaces that I added. Do I need to enable them somewhere or do a cisco os update?
mohammedmahmoud
Level 11
Level 11
Try removing and reinserting the PA and then do a "show diag".
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Mohammed Mahmoud.
