Integrated Routing and Bridging (IRB)
lionel valero
I cannot assign a bridge group to a subinterface :
interface GigabitEthernet0/1/3
no ip address
negotiation auto
interface GigabitEthernet0/1/3.3
encapsulation dot1Q 3 native
*** bridge-group 3 is not recognized by IOS XE Version 15.1(3)S1
interface GigabitEthernet0/1/3.228
encapsulation dot1Q 228
*** bridge-group 228 is not recognized by IOS XE
interface BVI3
ip address x.x.3.1 255.255.255.0
interface BVI228
ip address x.x.228.1 255.255.252.0
bridge 3 protocol ieee
bridge 3 route ip
bridge 228 protocol ieee
bridge 228 route ip
It appears that the bridge-group command is not available.
Reza Sharifi
Have you tried the command under the interface and not sub-interface?
no ip address
negotiation auto
bridge-group 3
yes i tried that because i read on a post that bridge-group should be set on the interface and sub-interface as well, but even on the interface the command is not available.
Regards.
Finally I was told that the "bridge-group" command in not yet available on IOS XE, and will be implemented in the next release. It is quite surprising.
Regards.
