inter net access by defferent vlan
arupbiet2006
hi,
hi create different vlan 10,20, 30 ,40,50,60.they r not communicate each other vlan with vlan 10.now i want to access internet each of vlan.
note:swith can capable to ping my dns
please give me some solution
Giuseppe Larosa
Hello Arup,
you can think to use multiple separated NAT pools one for each Vlan or to use only one.
Example with PAT over the wan interface
access-list 11 remark all vlans
access-list 11 permit vlan10.ipsubnet wildcard
access-list 11 permit vlan60.ipsubnet wildcard
on all vlan interfaces
int vlan x
ip nat inside
on interface to the internet
int vlan y
ip nat outside
ip nat source inside list 11 vlany overload
this is the simplest solution with PAT used on the public ip address of the wan interface
Try to implement this.
Hope to help
Giuseppe
hi Giuseppe
thanking you for reply .this configuration should be in router.
Hello Arup,
you can easily move the config on router
where you see
int vlan x
ip nat inside
change in the appropriate Vlan subifs
int f0/0.x
ip nat inside
If the router is after a L3 switch its inside interface will be only one for all of your vlans
Hope to help
Giuseppe
