Inter vlan Routing does not work
shahid_duet
Dear boss
I have cisco 3845 router  and 4507 & 2960 switch.  I have 4 Vlans on 4507  and connected to router on  four ports. Its working fine.
Now i want to create another vlan ( vlan 15 ) that trunk with vlan 20 and router port f0/0/1. i.e router F 0/0/1 ports belongs only two vlan(15,20) and need to intervlan routing. My conf. given below. but it is not working.
Switch conf:
interface GigabitEthernet3/1
description ## to router##
switchport trunk allowed vlan 15-21
switchport mode trunk
interface Vlan15
ip address 192.168.3.250 255.255.255.0
interface Vlan20
ip address 192.168.0.250 255.255.255.0
interface GigabitEthernet3/2
description ## To local lan-15 ##
switchport acc vlan 15
interface GigabitEthernet3/3
description  ## To Local lan-20 ##
switch port acc vlan 20
ip route 0.0.0.0 0.0.0.0 192.168.0.252
Router conf:
interface FastEthernet0/0/1
ip address 192.168.0.252 255.255.255.0
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
ntp broadcast
standby 4 ip 192.168.0.254
standby 4 priority 140
standby 4 preempt
standby 4 track GigabitEthernet0/1
standby 4 track FastEthernet0/0/0
standby 4 track GigabitEthernet0/0
interface FastEthernet0/0/1.2
encapsulation dot1Q 15
ip address 192.168.3.252 255.255.255.0
How can i do intervlan routing as ping from vlan 15 to 20.
shahid
2 Accepted Solutions
paolo bevilacqua
Configure some router subinterface for encapsulation dot1Q 20
Anyway since you have a layer3 switch, it is better to configure inter-vlan routing there and not on the router.
HI Shahid,
I am agree with Paolo.
you have to configure subinterfaces for encapsulation.
see the example:If you are configuring on Router
Create sub-interfaces, set 802.1Q trunking protocol and ip address on each sub-interface
Router(config)#interface f0/0
Router(config-if)#no shutdown
(Note: The main interface f0/0 doesn’t need an IP address but it must be turned on)
Router(config)#interface f0/0.0
Router(config-subif)#encapsulation dot1q 15
Router(config-subif)#ip address 192.168.15.1 255.255.255.0
Router(config-subif)#interface f0/0.1
Router(config-subif)#encapsulation dot11 20
Router(config-subif)#ip address 192.168.20.1 255.255.255.0
(Note: In the “encapsulation dot1q 15″ command, 15 is the VLAN ID this interface operates in)
Configure VLAN
Switch(config)#vlan 15
Switch(config-vlan)#name SALES
Switch(config-vlan)#vlan 20
Switch(config-vlan)#name TECH
Set ports to access mode & assign ports to VLAN
Switch(config)#interface range fa0/1
Switch(config-if)#no shutdown
Switch(config-if)# switchport mode access
Switch(config-if)# switchport access vlan 15
Switch(config-if)#interface range fa0/3
Switch(config-if)#switchport mode access
Switch(config-if)# switchport access vlan 20
see the example:If you are configuring on layer 3 switch:
ip routing
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/3
interface Vlan15
interface Vlan20
And on hosts just assign IP addresses and default gateways (to the corresponding interface VLANs) -> hosts in different VLANs can communicate.
Please rate if it helps
paolo bevilacqua
HI Shahid,
Configure VLAN
ip routing
interface Vlan15
interface Vlan20
Mr. Sandeep
Thank you very much for such clear concept with example.
shahid
smehrnia
Level 7
Level 7
Hi Shahid,
Agree with Paolo, from ur post i have this impression that u r mostly using Gigabit switched interfaces, doing intervlan routing on a "Router on a stick" fashion with Fastethernet interfaces could seriously slow down ur network. use the Layer 3 Capability.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
