06-06-2016 01:25 PM - edited 03-05-2019 04:10 AM
Hi everybody.
Does anyone have an example configuration of interchassis in the ASR 1001-X. I´m trying to set up this HA config but its not working properly.
I would like tu use this with MPLS and ISIS and have both ASR with the same IP management address.
Here is the config that I have:
Router-1 |
hostname Router_ASR-1001-1 |
redundancy |
mode none |
application redundancy |
group 1 |
name CISCO_HTTS_1 |
preempt |
priority 200 |
timers delay 15 reload 35 |
control Port-channel1 protocol 1 |
data Port-channel1 |
asymmetric-routing interface Port-channel2 |
asymmetric-routing always-divert enable |
group 2 |
name CISCO_HTTS_2 |
preempt |
priority 250 |
protocol 1 |
timers hellotime 1 holdtime 3 |
interface Port-channel1 |
description B2B HA - Data and Control |
ip address 192.168.103.2 255.255.255.252 |
load-balancing flow |
description HA - Asymmetric Routing |
ip address 192.168.104.2 255.255.255.252 |
interface GigabitEthernet0/0/0 |
description NOT USED |
shutdown |
interface GigabitEthernet0/0/1 |
description LAN_1 |
ip address 192.168.101.3 255.255.255.248 |
redundancy rii 666 |
redundancy group 1 ip 192.168.101.1 exclusive decrement 60 |
interface GigabitEthernet0/0/2 |
description HA - Data and Control |
channel-group 1 mode active |
interface GigabitEthernet0/0/3 |
channel-group 2 mode active |
interface GigabitEthernet0/2/0 |
description INET |
ip address <ip+mask> |
redundancy rii 111 decrement 60 |
redundancy asymmetric-routing enable |
interface GigabitEthernet0/2/1 |
description LAN_2 |
ip address 192.168.102.3 255.255.255.248 |
redundancy rii 777 |
redundancy group 2 ip 192.168.102.1 exclusive decrement 60 |
interface GigabitEthernet0/2/2 |
interface GigabitEthernet0/2/3 |
Router-2 |
hostname Router_ASR_1001_2 |
redundancy |
mode none |
group 1 |
name CISCO_HTTS_1 |
preempt |
priority 250 |
timers delay 1 reload 1 |
group 2 |
name CISCO_HTTS_2 |
preempt |
priority 200 |
protocol 1 |
ip address 192.168.103.1 255.255.255.252 |
ip address 192.168.104.1 255.255.255.252 |
ip address <inet> |
redundancy rii 222 |
description LAN_1 |
ip address 192.168.101.2 255.255.255.248 |
description INET |
description LAN_2 |
ip address 192.168.102.2 255.255.255.248 |
11-09-2019 05:52 PM
i think you should to separate the control link and data link, you made port-channel 1 for both of them.
look at:
