Interconnecting 2948G switch
vinoth.kumar
we are trying to cascade cisco 2948G-GE-TX with cisco 3500XL series but the link was not getting up
pleae let me know what are may be the root cause for the above issues
regards,
Vinoth
5 Replies 5
paolo bevilacqua
Need a crossed cable perhaps.
But we are connecting through fibre cabble
since 3524XL-EN series a only GBIC port and on the other end 2948G has GBIC ethernet port
So let me know what may be the rootcause
Vinoth
Sorry if it seems obvious, have you tried swapping the strands.
Can we go with connecting crosscable on the one of the port in both switch
can u help can i do the above connecting for this model 2948G with 3524XL
Basically, you connect fiber cable and swap it around until works. Another is using the cable to make a loopback in the port, hence proving cable and port are working.
