Interface controller statistics on Cisco 892
Hello;
I have customer complaining slow connexion, I have checked the router which is installed to site, the Lan side (interface going to his Lan), I fund this related to sh controllers gi 2 | begin Statistics, many Rx/Tx Bad Pkt Errors and Rx/Tx Oversize Errors
Is there some one who can explain me what is this parameters and do this can impact the customer connexion ?
thank you for your reply
router#sh controllers gigabitEthernet 2 | begin Statistics
Statistics:
Rx Bytes 395675843 Tx Bytes 2376209586
Rx Good Packets 2028702 Tx Good Packets 1762905
Rx Multicast 1639609
Rx Broadcast 647728
Rx Bad Pkt Errors 25212 Tx Bad Pkt Errors 2698
Rx FCS Errors 0 Tx FCS Errors 0
Rx Runt Errors 0 Tx Runt Errors 0
Rx Oversize Errors 25212 Tx Oversize Errors 2698
Rx Length Errors 0 Tx Collisions 0
Rx Code Errors 0 Tx Late Collisions 0
Rx Dribble Errors 0 Tx Excessive Collisions 0
Tx Abort Errors 0
Port Stopped: N
router#sh int gigabitEthernet 2
GigabitEthernet2 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 74a2.e6fe.26f1 (bia 74a2.e6fe.26f1)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 2/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
Last input 00:00:01, output never, output hang never
Last clearing of "show interface" counters 6d23h
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1102000 bits/sec, 716 packets/sec
5 minute output rate 7911000 bits/sec, 926 packets/sec
144591867 packets input, 48609843027 bytes, 0 no buffer
Received 738456 broadcasts (1500275 multicasts)
0 watchdog, 0 multicast, 0 pause input
200758860 packets output, 186262660976 bytes, 0 underruns
10071 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
the errors shown are less than 1 percent of the total packets, so that is likely not the reason for the slow connection. What type of connection do you have ? Is GigabitEthernet 2 the outgoing interface ?
