Interface down/down issue.
tresdeasada
Frequent Visitor
Frequent Visitor
Hi everyone.
I'm having some problems with an interface of my cisco router, actually, with any interface.
I have 2 internet connections in the place where the router is, one with DHCP and the other with static public IP address. When I connect the router to the public IP, te interface goes Status down, protocol down, when I connect it to the DHCP connection everything it's up, the interface works and my router goes to internet, not even the led indicator it's on with the public IP connection.
When I connect my computer to the port of the public IP, it has Internet access and everything works correctly, the problem is only when it is connected to the router, everything goes down as if it were a physical problem or something like that, but as I mentioned, DHCP works with the same patch cord.
Thanks for reading!
When you connected to laptop what speed you see on the laptop.
Suggest to default the interface and connect and see that the interface come up, once that is success you can configure switch post.
Do you have any config other side ? rukush side how the port configured ?
BB
19 Replies 19
Hello
@tresdeasada wrote:
Hi everyone.
When I connect my computer to the port of the public IP, it has Internet access and everything works correctly,!
Do you have the router interface hard coded ( speed/duplex)
What is the device your connecting the router to - you may require a cross-over cable?
Kind Regards
Paul
Both interfaces are hard coded and both interfaces goes to the same Rukus Switch.
I was thinking the same thing about the cable, only I do not have one on hand, maybe I should try with that.
Richard Burts
Can you post the configuration of both interfaces? Also please post the output of show interface for the two interfaces.
Rick
Rick
G0/2 is the interface connected to Public IP
G0/0 is the interface connected to DHCP
GigabitEthernet0/2 is down, line protocol is down
Hardware is CN Gigabit Ethernet, address is 1c6a.7a17.5662 (bia 1c6a.7a17.5662)
Internet address is 45.235.173.164/27
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Auto Duplex, Auto Speed, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 02:07:07, output 02:07:15, output hang never
Last clearing of "show interface" counters 00:01:59
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
interface GigabitEthernet0/2
ip address 45.235.173.164 255.255.255.224
ip flow monitor FNFnbarMON input
ip flow monitor FNFnbarMON output
ip virtual-reassembly in
duplex auto
speed auto
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 1c6a.7a17.5660 (bia 1c6a.7a17.5660)
Internet address is 10.213.100.61/23
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Full Duplex, 1Gbps, media type is RJ45
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 194
5 minute input rate 1702000 bits/sec, 171 packets/sec
5 minute output rate 80000 bits/sec, 92 packets/sec
14688361 packets input, 4287394085 bytes, 0 no buffer
Received 300477 broadcasts (0 IP multicasts)
3737 input errors, 0 CRC, 0 frame, 3737 overrun, 0 ignored
0 watchdog, 14440 multicast, 0 pause input
8688838 packets output, 1528552179 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
14440 unknown protocol drops
13 lost carrier, 0 no carrier, 0 pause output
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
What is the results if you connect to GigabitEthernet0/2 to laptop back to back is the port come up.
In this case what is the ISP side end device ?
BB
If I connect mi laptop to G0/2, the interface goes up, G0/2 works, it goes down only when I connect it to the Public IP port. That port goes to a Ruckus switch.
what happends when you connect latop configured with static IP and connect to ISP Ruckus switch and is that working ?
BB
That's correct, it works, when I configured the Public IP on my laptop and connect to Ruckus switch I have internet.
The problem is when I connect that precisely port (The IP public port) to my cisco router. So, the port to Ruckus works, mi cisco interface works, the problem happens when I connect them. Cisco Int <--> Ruckus
BB
I checked the speed on my laptop, 100Mbps, I was configuring in speed auto and at 1Gbps the router interface. It was just a matter of putting the interface with the speed that marked my lapton and the interface went up.
I did not check the ruckus parameters because I do not have access to them, it is part of the network of the building where my office is located and my task was to configure an internal router with output to that Ruckus switch.
Thank you very much for the help!
There's a disparity between your comment that the interfaces are hard-coded and the configuration you posted.
From Gi0/0 - Hard-Coded
From Gi0/2 - Auto
It's hard coded now, it still does not work.
Thanks for the reply!
OK. Is the Ruckus Side also hard-coded?
Could you post the following from the router:
1. sh ip int brief
2. sh run int gi0/0 and 0/2
3. From Ruckus switch, show running interface of the ports connected to the Cisco router.
For now, I assume the same cable type are used for both interfaces.
It was a speed issue.
GigabitEthernet0/2 is up, line protocol is up
Keepalive not set
Full Duplex, 100Mbps, media type is RJ45
THANKS FOR THE HELP!
