interface error
mohammady
Dears,
I have two E1 connections connected to 3745 router ,the ouput of show interface command for one of these interfaces gives a high counters value for input errors and CRC and the counters keep increasing ,also the relaibility of this interface has a value of 228/255??!!
what this indicates .????
paolo bevilacqua
Most likely your circuit is errored, check "show controllers E1".
HI, [Pls Rate all Informative POST]
Request your ISP to check / test the circuit. There are some reliability Issue reported.
Guru Prasad R
csco10716389
PLease contact your service provider and discuss about the reliabiliity of your E1 link.The reliability should be 255/255.Your current reliabilty shows that there should be some problem with the media.
Either
A. Circuit framing timing check the interface
sh controllers E0/E1
B.Layer 1 physical issue check with your ISP
