interface on router
harisapkota123
Level 2
Level 2
Dear all
I think the function of an auxilary port is to maintanance  a router from remote place using a modem. In my concept a modem
is connected with internet and in the other end i connect a router aux port with modem, then i can do everything with that router
like console access. am i right or wrong, if i wrong please clear my concept with correct answer,
Thanks all
Nagaraja Thanthry
You are correct. Typically, the aux port is used to connect a modem so you can manage the device remotely. Here is a configuration guide for accessing the router via aux port.
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080094bbc.shtml
Hope this helps.
NT
I generally put my 'out of band' managment modem on the console port instead of the aux port.  I do this because the console port will show you the boot trace; something the aux port wont do.  Also if the router is in ROMMON it's very helpful to be on the console to recover it.  The aux port is not so useful in an emergency.
Chris
