interface preconfigure GigabitEthernet0/0/0/X
Karlos
Hello everyone,
I am working currently on Cisco ios 9000 xr 6.6.2. when I try to display the interfaces by using Show IP interface brief or Show IPv4 int br. the only interface displayed is
Interface IP-Address Status Protocol Vrf-Name
MgmtEth0/RP0/CPU0/0  unassigned   Up  Up  default
So, the other interfaces are not shown. When I use Show run conf command it gives me like this
 interface preconfigure GigabitEthernet0/0/0/0
interface preconfigure GigabitEthernet0/0/0/1.
etc.
Please any solution ?
your interfaces are preconfigured, that is what explains the 'weird' output.
You can undo that by globally configuring:
no interface preconfigure GigabitEthernet 0/0/0/*
I am not sure if the '*' works in your case, if not, specify the interfaces individually:
no interface preconfigure GigabitEthernet0/0/0/0
no interface preconfigure GigabitEthernet0/0/0/1.
johnlloyd_13
Level 9
Level 9
hi,
does the "other" interfaces have IPv4 address?
did you issue a "commit" to apply the config?
