interface range command
sarahr202
Level 5
Level 5
Hi every body!
Let say i have a switch with 48 ports. if i want to select all of them for common configurations, how do i select them? My cisco book shows
interface range fastethernet 1/0-48
The question is why the book is considering the first port as 0?
if i have to select ports from fa0/1-24, how can i use the "interface range" to select this range?
thanks a lot!
Edison Ortiz
Port 1/0 can be a valid switchport in some modules.
Just understand what the command does and you can change that variable to accommodate your goal.
The important aspect is to understand that you can group a bunch of switchports and make changes to all of them at once. The switchport numbering may not always be the same depending on the platforms. You should also consider other type of interfaces such as; Ethernet, GigaEthernet and TenGigaEthernet.
interface range fa0/1-24
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
Props Edison!!!
Great answer.
Rating for you!
