Interface Slots and Service Module Slots
biplobkhan
Cisco 1900 , 2900 and 3900 have Interface Slots and Service Module Slots , My question is which type of card is support this slot.
Difference between this two slots ??? can anyone imple explain ?
Biplob
2 Accepted Solutions
sean.cross
Service Module Slots are used for router modules that run specific services that could be either Cisco proprietory or third party applications. These modules have their own processors, memory etc and don't use any of the router's resources.
The new Gen2 ISR's use the Enhanced version of SFP and copper GE interfaces to provide connectivity for high speed uplinks.
Please have a look at the link below for more information. On this page have a look a the link for Cisco Supported and Unsupported Modules for Integrated Services Routers. This document provides some very useful information for the 3900 series.
http://www.cisco.com/en/US/products/ps10536/products_relevant_interfaces_and_modules.html#newmod
I hope this helps.
Sean
Network Module slot is different than the on board WIC/HWIC slots. As SM,NM's have the specific hardware to support some services like onboard PVDM for voice support. Your E1 interface can go either on NM'S module or onboard WIC slot depending upon which E1 module you have selected.these voice E1 modules are supported both on NM'S and WIC slots.
6 Replies 6
sean.cross
I hope this helps.
Sean
Hi Sean
Good morning. Now Its clear to me. A lot of thanks. As my understand IPS or SCM module is Service Module and Etherent, NM module is Interface card.
So Voice Module is Service module or Interface module ?. If anyone choose 4 Port Voice Card then It install in service module slot or interface Slot ???
2. What is ISM Sl and PVDM Slot
Biplob
The 4 port voice card will be installed in the NM slot at the back of the router.
An Integrated Service Modules (ISMs) and Packet Voice and Video Digital Signal Processor Module (PVDM) are installed on internal motherboard slots in the router.
ISM Installation
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/Internal_Modules.html#wp1097074
PVDM Installation
http://www.cisco.com/en/US/docs/routers/access/2900/hardware/installation/guide/Internal_Modules.html#wp1055143
Sean
NM slot is differnent ? NM slot only for Voice card ?. if any one want E1 card then which slot it will be installed  ?
Biplob
HI
From Previous conversation I am understand EHWIC and Service Module Card and now understand NM is different module.  One port or two port E1 installed in WIC slot.
My question is: In Product Reference Guide I have found
3945E  --- Have 3 EHWIC , 4 Service Module,  0 ISM Module and 3 PVDM , 3 DSP SLot
3925    --- Have 4 EHWIC , 2 Service Module , 1 ISM Module and 4 PVDM , 4 DSP Slot
Question:
1. What is benefit of ISM ? when customer need ISM ? why not ISM slot in 3945E ?
2. By default PVDM slot is empty ? if customer chhose for Voice license then how many PVDM come with slot ?
3. 3945 E and 3925 have 3 and 4 DSP Slots by default how many DSP comes with and if customer want more DSP then its load separetly ?
Biplob
