05-14-2013 12:52 AM - edited 03-04-2019 07:53 PM
we have a cissco 4506-e switch with ios verion 03.02.05.SG . We ae currently facing a strange problem . Vlan interfaces configured in he switch are not showing input and output traffic, whereas the traffic is seen on the Gig interfaces mapped to the respective vlans . We also tried configuring the load-interval 30 , but there is no change . Interace 3/5 is mapped to vlan 5 . For this issue we have also done the IOS upgrade from 3.1.1SG to 3.2.5SG recently still the issue is same .
Vlan5 is up, line protocol is up
Hardware is Ethernet SVI, address is 3031.021a.43bg (bia 3031.021a.43bg)
Description: **data**
Internet address is 10.2.3.3/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
Last input 00:00:02, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
IPv6 L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
16643 packets input, 3068419 bytes, 0 no buffer
Received 16999 broadcasts (0 IP multicasts)
41879 packets output, 1994075 bytes, 0 underruns
0 output errors, 0 interface resets
GigabitEthernet3/5 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is ddef.233a.4b30 (bia ddef.233a.4b30)
reliability 255/255, txload 3/255, rxload 10/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is off, output flow-control is off
Auto-MDIX on (operational: on)
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 41871000 bits/sec, 7991 packets/sec
5 minute output rate 13950000 bits/sec, 6800 packets/sec
703828585 packets input, 842898712214 bytes, 0 no buffer
Received 11168 broadcasts (34 multicasts)
427012246 packets output, 77399495556 bytes, 0 underruns
0 lost carrier, 0 no carrier
interface Vlan5
description **data**
ip address 10.2.3.3 255.255.0.0
interface GigabitEthernet3/5
switchport access vlan 5
ip flow monitor Netflow-Mon input
spanning-tree portfast
Please suggest
05-14-2013 06:55 AM
Hello
Can you post the running config of the switch,
sh run
sh vlan brief
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
05-15-2013 08:28 PM
Greetings,
By default the 4500 Sup6/7 do not track Layer 3 (SVI) interface counters. You can enable them by adding "counter" to the SVI config.
For your above example:
config t
int vlan5
counter
end
Reference:
Good luck, and please share if this resolves your issue.
Matt
