07-18-2011 02:19 PM - edited 03-04-2019 01:01 PM
Recently we have installed 10G LAN&WAN modules in 7609,7606 routers and 6509 Switches .
we have inserted 10G LAN Module module in 4th slot of 7606 router and later we removed the 10G LAN module from the slot 4 but the interfaces still showing in the router for the module 4.
After reboot also these interfaces still are appearing
Please let me know how to remove these interface.
IGWR7606A#sh module
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE JAF1246AGQS
2 24 CEF720 24 port 1000mb SFP WS-X6724-SFP JAF1243BCLQ
3 4 7600 ES+ 76-ES+XT-4TG3C JAE14290NWH
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL JAF1243BGHE
IGWR7606A#sh int des | i Te
Te1/1 up up "Connected to 7606B : Member of Port-Channel 11"
Te1/2 up up "Connected to 7606B : Member of Port-Channel 11"
Te1/3 up up "Connected to 6509A: Member of Port-channel 13"
Te1/4 up up "Connected to 6509A: Member of Port-channel 13"
Te3/1 admin down down
Te3/2 admin down down
Te3/3 admin down down
Te3/4 admin down down
Te4/1 admin down down
Te4/2 admin down down
Te4/3 admin down down
Te4/4 admin down down
Te4/5 admin down down
Te4/6 admin down down
Te4/7 admin down down
Te4/8 admin down down
Thanks in Advance.......
Praveen Kumar Cherala
07-18-2011 02:28 PM
Praveen
A reload of the switch should have removed them from the config.
However the recommended way to do it is to set -
module clear-config
in the running config. Then you remove the module and it should remove the config. However you must set it before you remove the module. If possible could you reinsert the module, then set "module clear-config" then remove the module. That should then remove the config.
If you do the above make sure after removing the module you then clear the "module clear-config" from the running config.
Jon
