Showing results forĀ
Search instead forĀ
Did you mean:Ā
Internal hosts cannot access web server on internal ip with NAT in place for external traffic
budweyers
Hello!
I currently have two offices setup as follows:
Office A internal IP: 192.168.0.0 /24 with Draytek router
Office B internal IP: 192.168.1.0 /24 with Cisco 1941 router
Office B hosts a web server with internal IP: 192.168.1.17
The offices are connected with an IPSEC VPN between the Draytek router at Office A and the Cisco 1941 router at Office B.
The VPN connects through the same interface that is used for static NATing for external traffic to access the web server.
My issue is users at Office A are unable to access services on the web server using its internal IP 192.168.1.17 on the ports being statically NATed.  I'm wondering how to resolve this.
My config is as follows and I'm using XXX.XXX.XXX.XXX to represent my public WAN IP.
interface GigabitEthernet0/0
 description WAN
 ip address XXX.XXX.XXX.XXX SUB.NET.MAS.KKK
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
 no mop enabled
 crypto map VPN
interface GigabitEthernet0/1
 description LAN
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1.1
 description DATA VLAN1
 encapsulation dot1Q 1 native
 ip address 192.168.1.253 255.255.255.0
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat inside
ip nat inside source static tcp 192.168.1.17 22 interface GigabitEthernet0/0 22
ip nat inside source static tcp 192.168.1.17 443 interface GigabitEthernet0/0 443
ip nat inside source static tcp 192.168.1.17 80 interface GigabitEthernet0/0 80
ip nat inside source static udp 192.168.1.17 22 interface GigabitEthernet0/0 22
ip nat inside source route-map NoNat interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX
ip access-list extended NoNat
 deny   ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
 permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.0.0 0.0.0.255
route-map NoNat permit 10
 match ip address NoNat
6 Replies 6
saurabh18n
No route to 192.168.0.0/24 network
ip route 192.168.0.0 255.255.255.0 <your Tunnel IP address>
same on the another router also
ip route 192.168.1.0 255.255.255.0 <your Tunnel IP address>
I wondered about this but since everything else works through the VPN I was unsure. Thanks for replying so quickly!  I will test this tomorrow and let you know!
Unfortunately adding the route made no changes.  I am confident it's the static NATs in place that are causing the issue.  For a test I set up a static NAT for RDP to another server on the 192.168.1.0 network and immediately I could not remote desktop to it from the 192.168.0.0 network.  Once I removed it I had no issues.
hope u added it to both side..  and if u are accessing 192.168.1.17 NAT will not be in picture.  can u ping 192.168.1.17 from another subnet ?
Hey so to provide an update.  I modified my NAT statement for RDP and have successfully been able to access the server internally and externally.
The changes I made are as follows:
Original:
ip nat inside source static udp 192.168.1.XX 3389 interface GigabitEthernet0/0 3389
Updated:
ip nat inside source static tcp 192.168.1.XX 3389 XXX.XXX.XXX.XXX 3389 route-map NoNat extendable
Thank you again for taking the time to help me with this issue!
Cheers
budweyers
