Internet access for Cisco 881
sshultes
I'm trying to all access to the internet through my Cisco 881, once I add IP permit any any I get disconnected:
ip dhcp excluded-address 10.70.82.1 10.70.82.200
ip dhcp excluded-address 10.70.82.251 10.70.82.255
ip dhcp pool 10.70.82.0/24
network 10.70.82.0 255.255.255.0
default-router 10.70.82.10
dns-server 8.8.8.8 8.8.4.4
interface Loopback1
description For Monitoring
ip address 10.255.66.30 255.255.255.248
interface Loopback2
ip address 10.255.65.30 255.255.255.248
interface FastEthernet0
no cdp enable
interface FastEthernet1
shutdown
no cdp enable
interface FastEthernet2
shutdown
no cdp enable
interface FastEthernet3
shutdown
no cdp enable
interface FastEthernet4
description WAN Interface
ip address 10.82.20.10 255.255.0.0
ip access-group 110 in
ip access-group 124 out
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no ip route-cache
ip policy route-map Nat
duplex auto
speed auto
no cdp enable
crypto map topac
interface Vlan1
description LAN Interface Mapped to Fa0
ip address 10.70.82.10 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
no ip route-cache
ip local policy route-map Nat
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool custnat 10.255.66.25 10.255.66.25 prefix-length 30
ip nat inside source list 101 pool custnat overload
ip nat inside source list 124 interface FastEthernet4 overload
ip nat inside source static 10.70.82.16 10.255.66.26
ip nat outside source static 172.31.16.59 10.70.82.11 no-alias
ip route 0.0.0.0 0.0.0.0 10.82.20.1
access-list 99 permit 172.31.100.250
access-list 101 deny tcp any host 10.70.82.11 eq telnet
access-list 101 deny tcp any host 10.70.82.11 eq 992
access-list 101 deny tcp any 172.31.16.0 0.0.1.255 eq telnet
access-list 101 deny tcp any 172.31.16.0 0.0.1.255 eq 992
access-list 101 permit ip any 172.31.16.0 0.0.1.255
access-list 101 permit ip any host 10.70.82.11
access-list 110 permit ip 65.197.232.0 0.0.0.255 host 10.82.20.10
access-list 110 permit ip 209.67.131.0 0.0.0.255 host 10.82.20.10
access-list 110 permit ip host 8.8.8.8 host 10.82.20.10
access-list 110 permit ip host 4.2.2.1 host 10.82.20.1
access-list 110 permit ip 10.70.82.0 0.0.0.255 host 10.82.20.10
access-list 110 permit ip any host 209.67.131.160
access-list 123 permit ip 10.255.66.24 0.0.0.7 172.31.16.0 0.0.1.255
access-list 123 permit ip 10.255.66.24 0.0.0.7 172.31.100.0 0.0.0.255
access-list 123 permit ip 10.255.65.24 0.0.0.7 172.31.16.0 0.0.1.255
access-list 123 permit ip 10.255.65.24 0.0.0.7 172.31.100.0 0.0.0.255
access-list 124 permit tcp any any eq 443
access-list 124 permit ip any host 209.67.131.242
access-list 124 permit udp any any eq domain
access-list 124 permit icmp any any
access-list 124 permit ip any any
route-map Nat permit 10
match ip address 101
set ip next-hop 10.82.20.1
make the changes marked in bold (after you are finished post the configuration again so we can check):
interface Loopback1
interface Loopback2
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
shutdown
no cdp enable
--> no ip access-group 110 in
--> no ip access-group 124 out
no ip redirects
no ip proxy-arp
ip nat outside
no ip route-cache
-->no ip policy route-map Nat
duplex auto
speed auto
no cdp enable
--> no crypto map topac
interface Vlan1
no ip redirects
no ip proxy-arp
ip nat inside
no ip route-cache
--> no ip policy route-map Nat
--> no ip local policy route-map Nat
no ip http server
--> no ip nat inside source list 101 pool custnat overload
--> no ip nat inside source list 124 interface FastEthernet4 overload
ip nat inside source list 1 interface FastEthernet4 overload
access-list 1 permit 10.70.82.0 0.0.0.255
--> no access-list 99
--> no access-list 110
--> no access-list 123
--> no access-list 124
--> no route-map Nat permit 10
sshultes
That worked, thanks for the help and quick response.
Hello
@sshultes  if @Georg Pauwen suggestion changes worked could you please rate his post and mark as solved so to assist others who may have the same issue in the future.
Kind Regards
Paul
Deepak Kumar
I am checking your WAN interface configuration and NATing both are seems are wrong.
As
no ip redirects
no ip proxy-arp
ip nat outside
no ip route-cache
duplex auto
speed auto
no cdp enable
no crypto map topac
NATing Issue:
ip nat inside source static 10.70.82.16 10.255.66.26 ip nat outside source static 172.31.16.59 10.70.82.11 no-alias
ACL Configuration Changes:
No ip access-list extended 101
No ip access-list extended 110
No ip access-list extended 124
Ip access-list standard 1 permit IP 10.70.82.0
Route Map Configuration Changes:
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
