Internet access from 1841 router
fmatrine
Hi All,
refer the attached topology and config file for the routers.
Requirement is to serve the internet for both the lan subnets as shown in the diagram.
Will this config work or is anything else reuqires in terms of interface natting.
network.king
Level 4
Level 4
As per your Config , you have allowed only access to one ip and it also requires some addition
interface Fa0/1
Description Connected to Private_Router
ip address 192.168.165.30 255.255.255.252
ip nat inside --- add
interface Serial0/0/1
Description Connected to Service Provider
ip address 220.227.113.5 255.255.255.252
ip nat outside --- add
If you require for your lan also internet access , then you need to do PAT .
1.Configure a access-list to allow the source ips
access-list 1 permit 199.30.1.0 0.0.0.255
access-list 1 permit 172.16.2.0 0.0.1.255
2.Configure a PAT
ip nat inside source list 1 interface Serial0/0/1 overload
3.Configure nat inside in ur Internet router LAN interface
interface FastEthernet0/0
description Connected to Private Segment
ip address 199.30.1.10 255.255.255.0
ip nat inside
But Iam not sure 199.30.1.10 is ur public ip , but its not a private ip
Hope this helps
regards
vanesh k
I believe this is the configuration u can apply on your routers according to your network setup in the network diagram.
here it goes:
Internet_Router#
hostname Internet_Router
ip address 199.30.1.10 255.255.255.0( any reason for using a public range ???)
no ip proxy-arp
no ip mroute-cache
no ip redirects
duplex full
speed 100
interface Serial0/0/0
ip nat inside
no ip proxy-arp
no ip mroute-cache
no ip redirects
duplex full
speed 100
ip nat outside
no ip proxy-arp
no ip mroute-cache
no ip redirects
duplex full
speed 100
ip classless
ip route 172.16.2.0 255.255.255.0 192.168.165.29
ip route 0.0.0.0 0.0.0.0 220.227.113.6
ip nat inside source list 1 interface se0/0/1 overload
access-list 1 permit 192.168.165.28 0.0.0.3
access-list 1 permit 172.16.2.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
line vty 5 15
Internet_Router#
Private_Router#
hostname Private_Router
description Private Lan
ip address 172.16.2.1 255.255.255.0
no ip proxy-arp
no ip mroute-cache
no ip redirects
duplex full
speed 100
interface S0/0/0
ip address 192.168.165.29 255.255.255.252
no ip proxy-arp
no ip mroute-cache
no ip redirects
duplex full
speed 100
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.165.30
line con 0
line aux 0
line vty 0 4
Private_Router#
Hope this is clear.
Please rate if it does.
Cheers
Pallavi
jitesh1982
Hi Martin
i have gone through ur configuration .u havent define which interface is inside and which one is outside .
any way if u want to use internet from both lan do config as such
1)ip nat outside ( Serial Connecting Reliance ISP)
2)ip nat inisde ( for local lan and wan connecting other location )
3) access-list 1 permit 199.30.1.0 0.0.0.255 (permitting local lan)
access-list 1 permit 172.16.2.0 0.0.0.255 (permitting remote local lan)
access-list 1 permit 192.168.165.28 0.0.0.3 (permitting wan network so that u can ping ointernet from remote router also .it is optional )
4) ip nat inside source list 1 inteface serial0(outgoing interface) overload
No need of doing any config at remote end
If this doesnt work .then let me know so that i can give other solution
