Internet Access Problem
tsgurjar
I have connected my CISCO 1921 Router as show in diagram and configure it , but I could not get internet access in my LAN 10.60.100.0/23 , the configuration are as
DSLAMJP#show config
Using 1738 out of 262136 bytes
! Last configuration change at 08:03:08 UTC Tue Oct 5 2021
version 15.8
hostname DSLAMJP
boot-start-marker
boot-end-marker
enable password xxxxxx
no aaa new-model
ip dhcp excluded-address 10.60.100.1 10.60.100.10
ip dhcp pool LAN
network 10.60.100.0 255.255.254.0
default-router 10.60.100.1
dns-server 203.153.41.28 203.153.44.44
no ip domain lookup
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-3873411360
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3873411360
revocation-check none
rsakeypair TP-self-signed-3873411360
crypto pki certificate chain TP-self-signed-3873411360
certificate self-signed 01 nvram:IOS-Self-Sig#3.cer
license udi pid CISCO1921/K9 sn FGL190321FA
redundancy
interface Loopback0
no ip address
interface Loopback1
no ip address
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.255.241.26 255.255.255.252
description WAN
ip nat outside
ip virtual-reassembly in
duplex full
speed auto
interface GigabitEthernet0/1
description LAN
ip address 10.60.100.1 255.255.254.0
ip nat inside
duplex full
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
Ip nat inside source list 99 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0  10.255.241.25
access-list 99 permit any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password xxxxxx
login
transport input telnet
scheduler allocate 20000 1000
end
DSLAMJP#
Please help in this matter
pman
Have you checked that there is no routing problem?
Have you checked ping from address 10.255.241.26 to the internet?
Is there another router in the topology described where NAT is configured?
about the NAT
Cisco highly recommends that you do not configure access lists referenced by NAT commands with permit any. Using permit any can result in NAT consuming too many router resources which can cause network problems.
no access-list 99 permit any
access-list 99 permit 10.60.100.0 0.0.1.255
in addition to what @pman said, what is the router in the middle, the one with  IP address 10.255.241.25, doing ? That router needs to NAT as well, can you post the config of this device as well ?
