Internet connection interface configurations
Daniel Smith
I would like to be sure that our internet facing routers, and their interfaces, are as secure as possible. Searching the web has not yielded as much information as I had hoped. Please respond with your suggestions and tips. Thank you in advance.
trfinkenstadt
Daniel,
You can start with only allowing the traffic that needs to go through to go through.  For example, on my DMVPN edge routers, I only allow UDP500/4500, ESP, and DHCP style things:
ip access-list extended dmvpn-edge
 permit esp any any
 permit udp any any eq isakmp
 permit udp any any eq non500-isakmp
 permit udp any eq bootps any eq bootpc
 deny ip any any log
For a true internet router you could have a much more developed list than that.  Ensure that you have an ACL that controls what can ssh to your device in your "line vty 0 4" config.  Ensure that you allow your routing protocols to flow through to your providers.  Things like that.
best regards,
tim
johnd2310
Level 8
Level 8
Hi.
As a start have a look at the router hardening  guide.
http://www.cisco.com/c/en/us/support/docs/ip/access-lists/13608-21.html
Also look at the network security baseline.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/Baseline_Security/securebasebook.html.
Thank
John
**Please rate posts you find helpful**
